Old 01-05-2005, 10:59 AM
kasey3333 kasey3333 is offline
Whine when starting car
I have a 2001 Olds Intrigue and for the last 3 weeks I have been hearing a whine occassionally when I start my car (about every other day). It sounds like an electric drill motor and lasts less than a minute. The temp has been zero and below for about a week recently and I am wondering if this might be the problem. But this week the temperatures were up above freezing - and it is still doing it. I don't know!
Also - the car is still under warranty - is this something that would be covered? Can I ask the dealer to check everything out on my car before the warranty expires for no charge?
Thanks!
Old 01-05-2005, 08:25 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: Whine when starting car
power steering pumps can whine a little when cold. Check the fluid, too.
Also, you may be hearing the electric air pump. I think it's on the passenger side front lower.
Old 01-07-2005, 08:16 AM
Thanks for the reply. The sound is coming from the driver side under the hood. If it is the pump will I need to have it replaced or is it just an annoying sound.
Thanks!
Old 01-08-2005, 12:42 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
It's just an annoying sound. My girlfriends '99 Intrigue does the same thing when it's cold outside. Done this since she got the car in June 2003. I wouldn't worry about it because this is a common complaint. I don't know the science behind it but that's just the way it is.
Old 01-10-2005, 06:03 PM
illinoiswronski illinoiswronski is offline
> My girlfriends '99 Intrigue does the same thing when it's cold outside <
Try changing the PS fluid. I'm not sure why as I'm no expert on the finer details of power steering but this has worked in the past.
Old 01-12-2005, 12:27 PM
Smile
Thanks - I will try that!
Old 01-15-2005, 11:10 PM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
If the noise changes tone when you turn the wheel it is the P/S pump.
Otherwise the alternator will also make noise when it is extremely cold and the battery is low.
