Old 03-08-2002, 12:38 AM
jpp3773 jpp3773 is offline
Send a message via AIM to jpp3773
advice needed
i have heard many things about running a turbo with vtec. i have heard it is good, and i have heard it is bad. i plan on swapping in an engine into a 93 civic hatchback, and wichever engine i choose, either the lsvtec or just the regular ls motor, i am going to get the crower stroker kit with new valve springs and valves and retainers, as well as a port and polish of the head and i want to bore and sleeve my block. my question is, which motor would be best for the job out of the two i mentioned and out of all the b-series which would be best ?
Old 03-08-2002, 01:47 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
I wouldnt go LS/vtec route. Not because its not good or whatever, but because you're building an LS which would perform quite nice w/ turbo. And if you're building it, you will get better value if you spend it on making the bottom end bulletproof.
BTW I would recomend geting a LSD for your LS trans, dont get the type-R trans because w/ turbo the gears will be too short.
just my 2 cents
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 03-08-2002, 09:58 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
I would go with the JDM B16A. i think it's the best motor honda ever made and it has alot of aftermarket support to back it up. Good luck on whatever you choose.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
