Old 01-05-2005, 08:22 AM
420Hustler 420Hustler is offline
Send a message via AIM to 420Hustler
sound system
i was wondering if i would be able to put two 12" subs and a 900 watt AMP in my trunk ???
Old 01-05-2005, 11:29 AM
Chazman Chazman is offline
Re: sound system
Should be lots of room, but be sure to build the box to the speaker specifications.
Old 01-05-2005, 12:17 PM
jlogan421 jlogan421 is offline
Re: sound system
yeah, i put two 12's in mine and the box is not suppossed to be in a trunk so u shouldnt have a problem
Old 01-05-2005, 06:11 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Re: sound system
Just out of curiosity, is there a reason you're thinking you wouldn't be able too? There's a ton of room back there, especially if you make a custom enclosure out of fibreglass. Are you thinking you won't have enough room, or just worried about sound quality issues?
Marc
Old 01-06-2005, 06:44 PM
grandamiuknow grandamiuknow is offline
Thumbs up sound system
yeah it'll work. I have a 2002 grand am se 2dr and have two 12" infinity subs running roughly 600w ech from kicker 600w mono amp, most beautiful and sound is perfect. my car trunk has about 17 inches clearence into the trunk but about 18 throught the back seat if takin out. good luck man
2002 Pontiac Grand Am SE, SPW CF muffler, Sony head unit, Kicker 600w mono amp, 2 Infinity 12" subwoofer bridged from amp, working on L.E.D. underbody kit.
I recomend that anyone near Nashville, TN visit NextGear Garage in the Bellevue mall if you have an import or domestic tuner.
Old 01-07-2005, 08:23 AM
Re: Re: sound system
Marc
Yea im i was thinking both cuz my 1995 Grand SE has a small trunk and plus ive seen some of my friends put two 12" in theres and have to get every thing tightened cuz it loosend there there screws and everything and if it would have a bad sound or engine noise if theres not enough power.............
Old 01-07-2005, 08:47 AM
swalt's Avatar
swalt swalt is offline
If you are concerned about space, fabricate a back board and mount them up behind the rear seat (if your seats fold down, even better) Use the trunk as a box. When I did my Beretta, I had 4 12" subs in the trunk in an enclosure that resembled an "M" if you looked at it from above. The outside subs faced in from the side of the vehicle and the two in the center faced the outside two subs. When the seat folded down you could see all the subs. I replaced the trunk weatherstripping with a thicker molding to make the trunk air tight. As far as the amps, I built a tray for the rear deck to conceal them (I had problems with theft in the apartment I was living in) I had two amps in the tray (one ran the subs, the other the mids and highs). Had cooling fans mounted on each side and then a tray that mounted over top of the amp tray to conceal it all. (I used fabric speaker mesh tightly mounted around an MDF frame. To look into the back window tray you would never know a system was in the car and it only raised the height of the rear tray about 2".
Old 03-28-2005, 04:50 AM
streethoboz streethoboz is offline
Send a message via AIM to streethoboz Send a message via Yahoo to streethoboz
Re: sound system
In my '01 GA GT I have the back seats folded down, the amp sits on the big seat and my speaker box is pushed all the way up. It sits inside the car just a little bit.
Are you ready to meet your savior?
