Old 01-04-2005, 11:17 PM
spooky's Avatar
spooky spooky is offline
Send a message via Yahoo to spooky
Question another 4x4 actuator question
i recently replaced the front axle actuator on my 97 Z-71 with the electric motor upgrade along with the required wiring harness. 4 hi works fine, but when in shift into 4-low, the transmission doesn't want to shift properly. the new wiring harness is spliced into the brown transfer case wire. did i do something wrong, or did i overlook something else? thanks for any replies.
http://communities.msn.com/femur13
Old 01-05-2005, 10:02 PM
Jeremy-WI Jeremy-WI is offline
Re: another 4x4 actuator question
4LO does affect shifting, it should shift at a slower speed. Did you use 4Lo much before the new actuator
Old 01-05-2005, 10:18 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
My 4 low shifts much slower and much harder than in 2wd or 4 high. always has and if it holds together right always will, thats how it's supposed to be.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 01-06-2005, 12:29 AM
spooky's Avatar
yes i've used 4-low before mainly in sand dunes. it's as if the transmission doesn't want to shift out of first gear. it revs to 5,000 and won't shift into second.
Old 01-06-2005, 08:10 AM
Did you cut any wires that did not get reconnected somewhere, possibly the grn/blk wire at the transfer case switch? It sounds like the PCM doesn't know its in low range and operating on the high range shift points as far as speed/throttle position go
