Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 01-04-2005, 10:13 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
Angry check engine light on agian misfire???????
check engine light came on again it gave me 6 different codes P0301(cylinder 1 misfire detected) P0302(cylinder 2 " ") P0303 (cylinder 3 " ") P0304 (cylinder 4 " ") P1169 (primary heated oxygen sensor circuit LABEL high input (sensor 1)) dont remeber last one because i didn't right it down. last time i got the misfire detected i changed the spark plug wires and spark plugs. now i dont know what to do. could it be bad gas or maybe water in the gas???? any ideas of what to do will help lots.??????
it better get me to wyoming
Old 01-05-2005, 09:20 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: check engine light on agian misfire???????
any aftermarket fuel parts?
could be your injectors. whats the mileage on em?hows the ignition timing? i suggest checking these two because you also have a code for the o2 sensor. could be bad gas, but, have you used up the old gas yet?
also, the misfire went away when you swapped the plugs? for how long?
what was the other code? maybe helpful.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-05-2005, 10:15 PM
turbcivic's Avatar
turbcivic turbcivic is offline
is it a 96 with less then 150,000 miles? If so, take it to honda. There was a emission extension. Plugs, wires, cap, rotor, oil change, and check for set DTC's. All free of charge.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 01-07-2005, 09:01 PM
its a 97, theres no aftermarket fuel parts, dont no mileage on injectors but the car has 120,000, timings fine, it seems to give dtc for misfire after i put a full tank of gas in so next time im just gonna put bottle of fuel system cleaner in and higher octane gas
Old 01-07-2005, 10:44 PM
turbcivic's Avatar
try a fuel induction service
Old 01-10-2005, 05:35 AM
hontoy's Avatar
hontoy hontoy is offline
Banned
DID THE CODE DISAPPEAR WHEN YOU CHANGED THE WIRES AND SPARK PLUGS? COULD BE JUST THE MONITOR. THAT MEANS YOU NEED TO DRIVE YOUR CAR IN ALL CONDITION STOP GO HIGH AND LOW SPEED FOR ABOUT 50 MILES. THE CODE SHOULD CLEAR AFTER YOU DID THAT.
Old 01-10-2005, 09:10 PM
i made it disapear when i cleared it with the computer
