Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-04-2005, 09:10 PM
chuck colemer chuck colemer is offline
2001 dakota terrible brakes
2001 dakota, when braking on dry payment,the truck hops pretty bad I think the front is doing all trhe stopping,if any loose gravel or slipprey conditions it is dangers trying to stop front wheels keep sliding,need help Thanks
Old 01-05-2005, 01:01 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: terrible brakes
Sounds like you have a very badly warped rotor. If your truck slides around while trying to stop, that's not just brake related, your tires are causing that being that they are getting enough traction.
Old 01-11-2006, 04:34 PM
Burt the Boater Burt the Boater is offline
Smile Adjust the Rear Brakes
Any idea if the rear brakes (drums) have been adjusted? The Dakota Club website reported the drums do not self adjust as well as within other drum brake systems. I adjust the rear brakes on a periodic basis (maybe every 10K miles).
Cheers,
Burt
Old 01-11-2006, 08:45 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: terrible brakes
I agree with the warpped rotors idea. Another idea may be to bleed your brakes. One side may be recieving more presure than the other. Also, have your alignment checked as that may also be the problem.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
