Old 01-04-2005, 09:07 PM
suecurrin suecurrin is offline
no heat on 93 escort
I started out with no blower, replaced it and it jams, but I have no hot air flowing, only cold even after driving 6 miles, all help is appreciated
Old 01-05-2005, 12:20 AM
mlw35405 mlw35405 is offline
Re: no heat on 93 escort
check the linkage that runs from the control panel - it's cable driven and often the clip comes out. On the passenger's side below the dash (on the side of the middle console), look for a white plastic "gear". It should move back and forth as you move the control from cold to hot. If not, see what's come loose. This is, of course, assuming that the engine is coming up to operating temperature...
Old 01-05-2005, 11:59 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
:agree: if ur engines not making temperature, head for the thermostat...
Old 01-05-2005, 06:03 PM
i changed the thermostat and still have no luck. after the car heats up to the normal mark it will throw heat for 30 sceands and then back to cold. what to do?
Old 01-06-2005, 10:08 AM
Jet-Lee's Avatar
Banned
when this happened to me, it was cause I didn't have enough coolant. And it wasn't at least 50/50. I ended up freezing my block, completely. Flushed the system, new thermostat, all is good.
Lucky I didn't crack the block.
