Old 01-04-2005, 07:13 PM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Question A Question maybe you guys can answer
ok when my car starts off it goes fine in first gear when it hits second its like it looses power then it gets to third and the power comes back? what is up with that??? every gear except second is fine??
Old 01-04-2005, 09:29 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: A Question maybe you guys can answer
im assuming its an automatic, also, what kind of driving? just regular easy driving, or hard full throttle racing? also what year? engine? tranny? this will help decide the problem.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-04-2005, 09:43 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
if its an automatic , ive heard of this issue before and it ended up being the sun shell.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 01-05-2005, 12:40 AM
Re: Re: A Question maybe you guys can answer
just regular driving it is an automatic its a 95 3.4, i know not a big engine but this has been bugging me....there is a big difference when it hits second gear.....
Old 01-05-2005, 01:08 AM
Morley Morley is offline
Possibly the torque converter switch (solenoid) is locking the TC up in second for some reason.
Old 01-05-2005, 07:03 AM
Jenn07 Jenn07 is offline
I have the same year car and same engine.. mine dose something like that to.. if i start off super gentle it wont do that ... if i put the throttle to the floor then it dosent like to shift... until after 3rd.... its weird
Old 01-05-2005, 01:25 PM
89IROC&RS's Avatar
ok, by loosing power, describe as best you can what happens, does the engine bog, rpms go down, car slows, or do the rpms go up, but the car stops accelerating.
if the rpms drop with the speed, it may be transmission and it may be engine. the rpm drop from first to second gear is very large in the 700R4, it leads to a bog in some engines. which is most noticeable at low rpms. The transmission may be fine, but the rpm drop from 1st to 2nd may be highlighting a beginning engine problem. so thats something to look into. check your air fuel and spark to make sure everything is fine. perhaps you are due for a tuneup.
If the rpms go up while the car is slowing down, you may have a burned up clutchpack, or the sunshell like 92rs25th suggested. or some other internal fault.
Tranny work is really expencive and hard to do, so i would look at the engine as a starting point, also because the clutchpacks for the second gear are shared by the 1st gear, so if you loose one, you should have lost the other as well.
Old 01-05-2005, 02:49 PM
My car the rps dont go up or down.. it will go up until it sounds like it needs to shift in to third then stays there alittle bit and takes it time shifting in to third.. then it is fine it just has a rough time going for second to third..
Old 01-05-2005, 08:38 PM
89IROC&RS's Avatar
sounds like it might be a weak band or low transmission fluid. check your trans fluid level with the engine running, for what ever reason it would seem that your line pressure isnt high enough in second gear to shift normally. If its internal failure such as a band or sun shell your probly gonna need to take it to a transmission shop.
Old 01-06-2005, 09:26 AM
... fluids are good....? what band?
Old 01-06-2005, 12:45 PM
89IROC&RS's Avatar
Inside the transmission there is a pressure band, ill be completely honest, i dont know exactly what it does lol, dont know alot about tranny design, havent had a chance to take a class on them, but i believe it applies pressure to the clutch packs not unlike a clutch spring, if it was not working right, the shift would not be happening normally.
also something else i thought of, is a shift solenoid. the modern automatics are computer controled, and rely on solenoids to actuate the fluid valves. If this solenoid goes bad, it may cause the condition you are having.
again i apologize that im not more helpuful, im taking shots in the dark baised on what i remember my tranny guy working on at the shop. so there are holes in what i remember.
Old 01-06-2005, 02:21 PM
thanks for the help... shots in the dark are better than anything i can come up with.. I know almost nothing about cars!!
Old 01-06-2005, 04:41 PM
i have just gave the car a tune-up so thats done...it seems that at the beginning of second its almost like the rpms are too low and the car doesn't like it..lol...maybe its normal....it seems low rpms bogs the car down....but the rpms are just low at the beginning of second...i don't know what it is.....
Old 01-06-2005, 07:18 PM
89IROC&RS's Avatar
what engine speed to the shifts occur at?
Old 01-06-2005, 07:23 PM
i think it shifts around 20?
