Old 01-04-2005, 06:54 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
idle problems
I have a problem with my car stalling when not shifting fast enough. The other day i replaced my battery and when i did and started it back up i noticed my RPM's were like 200-300 lower then before i changed the battery , it now sits at 800 maybe 700 rpm and before it was atleast at 1110-1200 rpm. Would anybody know what could be causing this?
Old 01-04-2005, 07:47 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: idle problems
search for idle
Something new is coming...
Old 01-04-2005, 07:52 PM
GotGrip666's Avatar
Banned
Re: idle problems
i have i havn seen anything pertaining really to my problem
Old 01-04-2005, 09:22 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
is your car turbo????????
if it is...check your bov dump tube hose..if it is loose/hanging off..your idle will drop
PS>>>>post what kind of car you have in your SIG...it helps
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 01-04-2005, 09:28 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: idle problems
Well for one, your idle SHOULD be 700-800, not 1100-1200. Also, are you recirculating your BOV? You should be (assuming you're on the stock mas setup).
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 01-04-2005, 10:11 PM
GotGrip666's Avatar
Banned
Re: idle problems
yea its recirculating and i have a 96 gsx manual trans, is the dumptubpe the tube from my bov to intake cause i took it off the other day to check my turbo and i couldnt quite get it back on as far as it was , it seems like its on there tight. Oh and a big thing i forgot im having white smoke come out the tail when im idle and whe i shift
Old 01-05-2005, 01:38 PM
1st off all...eliminate one possibility and get the bov hose on tight..it is the hose from your bov to intake...that can cause idle to drop...and white smoke could be a few things...anyone with some knowledge feel free to correct me if im wrong....
---bad head gasket
---bad turbo(b/c mine was cracked and I had some smoke from my exhaust and then i replaced it and the smoke problem went away)
---could be lack of coolant
im not 100% sure about them and i believe there are more possibilities
time to go check a 90 gsx out with roack2k2(mike)
-good luck man
Old 01-05-2005, 02:02 PM
GotGrip666's Avatar
Banned
Re: idle problems
its not the turbo because i just put a brand new t3/t4 in it so maybe its the headgasket
Old 01-05-2005, 04:43 PM
GotGrip666's Avatar
Banned
Re: idle problems
can i get a new bov dump tube at autozone? cause the one i have is ripped on the end , and besides that i can get it to go more then a half of an inch on the tube on my intake, would some lubricant help?
Old 01-05-2005, 05:16 PM
Lubricant will help...dont over do it
make sure you clamp it down if you can,..should have a stock clamp with it i believe(1st gens do i know)
i bought new coolant hoses at auto zone..im sure they have something to match your bov hose...bring in your hose when you go in
Old 01-05-2005, 11:29 PM
gen2gst95 gen2gst95 is offline
while were on the subject of idle, every now and then my car shakes a little bit. the rpms are fine, but ill be sitting at a stoplight or something and it will shake a bit like a big ass gust of wind when by. What could cause that and stuff
Old 01-05-2005, 11:30 PM
oh and my engine is stock for now and i am recirculating my BOV
Old 01-05-2005, 11:34 PM
GotGrip666's Avatar
Banned
Re: idle problems
idk
