Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-04-2005, 06:05 PM
punkrockdario punkrockdario is offline
95 jimmy nut kit installation
ok. i replaced my cpi, still not much of a change. but i just got the nut kit from gmpartsdirect.com
i just want any and all help or advice for this to go on. and i prey that this is the last thing i have to do to get my truck running.
i love my jimmy, even if it dont love me back
Old 01-05-2005, 06:25 PM
chembrad chembrad is offline
Word to the wise, unless you want to pull off your lower intake manifold and replace the lower intake manifold gaskets, be very careful removing the torx screw that holds the clamp for the fuel lines.
And the beauty of it is that this torx screw (27) has a round head and has been red thread locked ... So make sure your torx bit fits very snug.
Now having to pull off a 10 year old lower intake manifold is not such a bad thing. As it turns out I had some major carbon build-up blocking some of the passages. So cleaning that out will definitely improve performance on a clogged engine.
Old 01-05-2005, 06:29 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 95 jimmy nut kit installation
Becareful... The torx on both my trucks (92 and a 95) were a t30 and the ones that came with my replacements were t30. If you are unsure, always start with the biggest and work your way down. Use the first one that fits.
Old 01-05-2005, 07:11 PM
The replacement nut kit from gmpartdirect should come with a replacement torx screw. It is easy to see which torx fits snuggest on the new screw, then try it on the one in your Jimmy.
Old 01-07-2005, 10:04 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, the torx bit should have ZERO play when in the screw.
If you can wiggle it, it is too loose.
I used a small racket with a bit adapter and the right bit and I had the screw out in 10 seconds.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-09-2005, 11:53 PM
For the record, the torx bit is a T30. My bad. Good catch guys.
Old 01-10-2005, 04:47 AM
rlith's Avatar
Heh, it's half the time why people strip them out!!! LOL
Old 01-10-2005, 11:06 AM
BlazerLT's Avatar
AF -Advisor
Very true.
Old 01-14-2005, 01:45 PM
Some of us have to learn the hard way...
