Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-04-2005, 04:47 PM
240mph's Avatar
240mph 240mph is offline
***oil Leaks Everywhere Someone Please Help***
ok here are the problems. there is a slight leak coming between the oil filter and the block, i tightened the oil filter but still leaking.it doesnt look like it is coming from the hose line coming out from the oil filter unit it looks like it is coming out right in between the block and the unit. the next leak i have no clue because it looks like it is coming from the crankshaft cover.the leaks just keeps drippinng from the cover.i havent had time to open it up and take a look.and then the next was the oil pan drain bolt but i got that re-threaded but i didnt have hondabond to put on the pan so i used that bead-n-seal (jv6) but for some reason it looks like it is leaking from the pan to. do i need to re-apply hondabond on it.some please help me out thanks
Old 01-04-2005, 05:27 PM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
recently i had a problem with a burning oil smell coming inside of the car with the heat on. No visible leak was apparant. I took it to the shop they replaced the valve cover gasket, some spark plug gaskets and some other gaskets in under the cover. That fixed the problem and cost under 100 bucks. Hopefully this helps a little.
Old 01-04-2005, 06:39 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: ***oil Leaks Everywhere Someone Please Help***
try checking oil pressure switch, or if the filter is dbl gasket, i doubt the dbl gasket though
Old 01-05-2005, 02:12 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
This is kind of a shot on the dark buuut....you said you tightened the oil filter. If you tighten them too much, the small rubber seal can become pinched, and the oil will leak. My dad did this once quite some time ago. Make sure you only tighten it hand tight.
Old 01-05-2005, 04:38 PM
crzyCollegeKid crzyCollegeKid is offline
don't forget that when you are installing the filter, get some new oil and put it on the seal before you put it on
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 01-05-2005, 04:47 PM
240mph's Avatar
ok i just cleared up that it is not coming from the oil filter itself it is coming between the oil coler and the block where the filter is connected to.what should i do.and do they make gaskets for my 1997 h22 or do i just apply hondabond. and also what do you guys think about the leak coming from the side.thanks for your help
Old 01-05-2005, 08:45 PM
ruffusrex ruffusrex is offline
yes there is an o ring between your oil cooler and block. as for the side, just hope that it's not leaking from your oil pump because its a bitch to try to properly reseal the oil pump. if you need an illustration of the assembly let me know. i'll send it to you via email.
Old 01-06-2005, 04:31 AM
240mph's Avatar
why would it be the oil pump though??? the mileage is still really low and i hardly race that car.
