Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-04-2005, 04:07 PM
GunsnRoses88's Avatar
GunsnRoses88 GunsnRoses88 is offline
Send a message via AIM to GunsnRoses88
belts squealing
94, my belts have started to whine, is there a way to make them quit besides getting new belts?
Old 01-04-2005, 04:37 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
Re: belts squealing
There's some stuff you can pick up at an auto parts store, but it doesn't stop the noise for very long. New belts aren't that spendy, so I would definatly recommend just to change them
Old 01-04-2005, 09:12 PM
Audiobahn77 Audiobahn77 is offline
Re: belts squealing
I'm having the same problem.....this will be my 3rd belt in 38,000 miles. I think my adjuster pulley is actually what is making the belts bad or they just seem to wear out after 12,000 miles. It's kind of annoying. Is this the normal wear time for them? I sprayed a little WD40 on it and it was quiet for about 10 seconds. It seemed a little more quieter once I sprayed the pulley (bearing, if there is one).
Old 01-04-2005, 09:44 PM
Re: belts squealing
i have no idea i got it in june or july and this is this first time the belts have squealed
Old 01-04-2005, 10:23 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: belts squealing
use a bar of soap on the ribs/grooves of the belt, dry bar soap not liquid soap. this will take care of that annoying squeel.
Old 01-05-2005, 12:32 AM
Re: belts squealing
The smooth side of the belt is getting shiny. That is why I figured it was the belt again. What brand or kind of dry soap? There are different kinds of dry soaps.
Old 01-05-2005, 06:47 AM
Caribbean ZJ Caribbean ZJ is offline
Re: belts squealing
could be ur water pump seal or coolant leak
Old 01-05-2005, 08:11 AM
Re: belts squealing
how would that make my belts shiny? especially the coolant leak?
Old 01-05-2005, 08:23 AM
Re: Re: belts squealing
it doesn't matter which brand of soap you use.
Old 01-05-2005, 09:15 AM
Re: belts squealing
coolant would lubricate the belt causing slippage, thus squealing.
Old 01-05-2005, 09:18 AM
Re: belts squealing
how long should the belt last? As I said before, this is my second belt in 38k miles, now needing a third.
Old 01-05-2005, 09:20 AM
Re: belts squealing
it should last way longer then that, they are suppose to be replaced every 60,000 miles according to the book, so 1 should last at least that long (60,000 miles).
Old 01-05-2005, 05:19 PM
Re: belts squealing
so just put dry soap in the grroves, along the edges or like inside the belt
Old 01-05-2005, 08:30 PM
Re: belts squealing
let me know how it turns out Guns........then I might try it for mine.
I didn't see a coolant leak anywhere.
Old 01-06-2005, 09:45 AM
Re: belts squealing
Yes, just rub the soap in the grooves of the belt, u don't have to pack the soap into the grooves - just rub it on.
