Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-04-2005, 03:41 PM
spell spell is offline
Coolant Temp Sensor for gauge
I bought a replacement coolant temp sensor for my 1997 Jimmy and it has a plastic plug-in type of connection with 2 leads in it. I went to replace it and the one on the car is a single wire connected with a slide connector(not the plastic plug) Following the wire up to the inline plug, it looks to be all original. I've been looking around for a replacement and they all have this 2 plug connection. Does anyone know what the deal is or if this second wire can be bypassed/ignored on the new sensor?
Thanks
Scott
Old 01-04-2005, 04:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Coolant Temp Sensor for gauge
Sounds like you got the wrong sensor.
There are two sensors, one for the computer, and one for the gauge in the dash.
The one for the dash is in the middle driver's side of the engine.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-04-2005, 04:21 PM
"The one for the dash is in the middle driver's side of the engine."
That's the location of the one I'm trying to replace. What would you call that one vs the computer sensor? The new sensor I've got and the one I keep asking for is called the coolant temp sensor. Should I be calling it something else?
Old 01-04-2005, 04:33 PM
BlazerLT's Avatar
AF -Advisor
Ok, is the connector that is going to the existing one will slide into the new one.
Will it connect?
Old 01-04-2005, 05:05 PM
No. Two different plugs. The new one has the plastic plug that clips on. The existing one has a metal single slide on connection(wire connection slides over metal male end on temp sensor about 1/8" thick, round). A lot fatter than the pins in the plastic plug.
