Old 03-07-2002, 08:24 PM
Jarflow Jarflow is offline
Send a message via ICQ to Jarflow Send a message via AIM to Jarflow
head swapping
a b18b1 is a b18b1 correct, the year of the motor doesnt change anything, cause i wanna put a b18b1 head from a 96 teg on a block from a 90 teg b18b1 cause then ill have a non-vtec race kah
My car is like my own personal universe, shes my drug and it only takes twelve bucks to fill her up, but in my galaxy there aint no room for earth, so im leaving it cause i can feel the oil pressure building up, turning over thee ignition of my solar system, check the gauges, push in the tape, put my foot on the brake, shift exsistance, light my ciggarette and take it state to state until i crash into my fate
Old 03-07-2002, 10:35 PM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
Did either of those years of b18b1 have vtec? I have a 98 b18b1 (25,000mi....hooha) and its not vtec. I am just wondering, trying to get the engines/years down....
Old 03-07-2002, 10:46 PM
non-vtec =]
the head on a stock block made 220 hp and the block im putting it on is worked and has crower rods bored .30 over and other shit so hope things go well for me and they will bolt up
Old 03-07-2002, 11:38 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
So you want to put a 96 Integra (B18B1) Head on a 90 Integra(B18A1) Block? I dont really see the point in that. Are you trying to get LSVTEC out of this? If you are, use the 99-00 Si head(B16A2). As for the motors, 90-93 LS, GS, RS had the B18A1, 1.8L DOHC NON VTEC 140hp. The 92-93 GSR has a B17A1, 1.7L DOHC VTEC 160hp. The 94+ LS, GS, RS had the B18B1, 1.8L DOHC NON VTEC 142hp and the 94+ GSR had the B18C1, 1.8L DOHC VTEC 170hp. I think that's about all you need to know.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-08-2002, 01:15 AM
so it will bolt up
Old 03-08-2002, 06:46 AM
SleeperTeg's Avatar
OK...so you actually have a '90 b18a1 block and a '96 b18b1 head......are they both open deck or closed? Hope you got new pistions too....
Old 03-08-2002, 12:35 PM
why new pistons and what compression would you recommend
Old 03-08-2002, 12:51 PM
SleeperTeg's Avatar
If you are going through the trouble of tearing your bottom end down, you might as well do it all (or at least some). As far as what you do is going to depend on your application. What do you want to do? N20, boost, all motor....??
All I am saying is while your down there, ballance your rods and throw some forged pistons in. As far a compression....that too depends on you application. If your going NA use high compression (11:1+). If your going to run boost (N2O, TC, SC) use lows (9.8:1-).
Good luck! :smoker:
Old 03-08-2002, 01:02 PM
the compression in it now is extreamly high
its 12.5:1 i know i wanna lower the compression from that cause it cant even go threw the higher rpms if you dont have a 104 octane
i wanna go all motor threw this years and next years season and then prolly gut the car and boost her up =]
i would like to break into the 12's all motor which is a big ass goal but possible
Old 03-08-2002, 01:58 PM
SleeperTeg's Avatar
I thought this was a stock b18b1? If so, how do you get 12.5:1 out of it?!?!? Get lower compression pistons and ballance the bottom end. Will run kinda weak from what you are used too, but wait till you get that turbo.........oh baby!!
What else have you done to prepare for this badass engine?
Old 03-08-2002, 02:01 PM
nuthin stock about it
Old 03-08-2002, 02:04 PM
SleeperTeg's Avatar
well, indulge...
Old 03-10-2002, 12:46 AM
Rgacke's Avatar
Rgacke Rgacke is offline
"90-93 LS, GS, RS had the B18A1, 1.8L DOHC NON VTEC 140hp. "
wrong, 90-91 only had 130hp, 92+ had 140 and thats when it was changed to b18b. The change in the head gave it more HP, the blocks are all the same. I believe the serial # is right but easy as it seems I can not find a reliable source of what the exact serial # is for 92-93, even the honda hybrid pages has incorect specs and yes the head will bolt up to the block
"shut the door Joshua, and let death pass by..."
