Old 01-04-2005, 11:14 AM
konatjo konatjo is offline
Where's my lighter fuse??!!
My lighter quit and I don't have a manual. Can anyone help me? Oldsmobile Intrigue 2000.
Old 01-16-2005, 12:40 AM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
To access your in car fuses, open your drivers door and look at the side of the dash. Pull off the cover. There should be a fuse remover in there, otherwise you can use a pair of pliers. Just check the fuses to see if any are burnt out.
The Lighter should be a 30 Amp fuse.
Old 01-16-2005, 08:46 AM
Re: Where's my lighter fuse??!!
Renegeade2k, I thank you for trying to help. That was the first place I looked. I know there has to be one under the dash but I don't see obvious signs of it. If you have the manual, you can look it up and see just where it is at. And thank you for replying to my ad, you are the only one in all this time.
Old 01-16-2005, 01:08 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
my 2002 owner's manual shows the lighter fuse on the rt side inst panel fusebox on the 3rd column over and the 4th row down, it shows as a 20A
Old 01-19-2005, 10:24 AM
Re: Re: Where's my lighter fuse??!!
Well, that was where it is. I thank you. I understand it is just a lighter but now I am able to charge a cell phone or use a tire air compressor. These are important things when on the road. This puts my mind at ease. Thank you, again!
