Old 01-04-2005, 08:34 AM
jetaylorpb's Avatar
jetaylorpb jetaylorpb is offline
New to me Blazer w/problems
Just picked up a 97 Blazer, it's actually for the wife and kids. I've done some searching on this forum for some of the problems but I have others. Money is tight so I want to do as much of this as I can, just so you know the most I've ever done on a vehicle is change plugs, distributor and wires. I did drop the feul tank on my S-10 once.
Front Wipers - sometimes work, via this forum it appears to be the pulse board? I called the dealership and it's not covered under warranty. What should I expect to pay for the board and is it something easily done?
Rear Wiper - when I try to use it it just makes a clicking sound. Any idea what needs to be fixed?
Fluid Sound - when accelerating from a stop or turning at low speed I can hear a fluid sloshing around, sounds like it's under the center console. Happens even after filling the feul tank. Any ideas, is it normal or is something wrong?
Found out the dealership unplugged the check engine light, is it hard to get working again? I assume I have to pull apart the dash or is there a fuse they may have pulled?
Engine Codes - went to Autozone and they got a P0140 and P0141: the Haynes book says downstream O2 sensor, is that the one after the cat? Is there anything else to check before spending the $ on the sensor?
P1406 - the other code I got for the EGR Sensor. How best to fix this? Do I just replace the valve or sensor? I think I saw mention of just cleaning the valve. Is that easily done and will it solve the problem?
Edit - was in a hurry to post so I forgot to thank you for any help in advance.
Old 01-04-2005, 09:31 AM
Fireplug Fireplug is offline
Re: New to me Blazer w/problems
If you got it at a Dealer TAKE IT BACK ASAP and tell them to FIX IT
Old 01-04-2005, 09:42 AM
clariveros's Avatar
clariveros clariveros is offline
jetaylorpb, Dude how long ago did you get this vehicle
"Found out the dealership unplugged the check engine light" <---take that thing back you are getting shafted big time!!
I love my Jimmy but it sound like you got bent over
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
Old 01-04-2005, 09:49 AM
jetaylorpb's Avatar
You didn't see the crap I traded in for it. A 97 Maxima that needed $2000 to pass inspection and a 94 Cherokee that I had to have towed there cause due to a coolant leak and not driving it for 4 months the 100% water in the engine was frozen solid, it also needed ball joints and exhaust, they gave me $1000 for it though.
I got the Blazer as is knowing it would have some problems, so far it is not as much as it would have been to fix the trade-ins. O2 sensor is only $54, EGR is $120 but that may be able to be cleaned?
Old 01-04-2005, 11:01 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Take it back ASAP and if they say no, get a lawyer.
This is illegal.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-04-2005, 11:13 AM
jetaylorpb's Avatar
If I couldn't afford $2k to fix a Maxima how do you expect me to hire a lawyer? Have you ever dealt with them before? I have and they are not cheap. Some jerk forged my name to a contract and sued me and no lawyer would help without a couple thousand $ down. If I raped or murdered someone I could have had a free lawyer.
But anyways it looks like no one wants to answer the questions. Come on really, what am I looking at, a few hundred in parts, bloody knuckles and I may find a swear or two in me I never knew were there.
Old 01-04-2005, 11:31 AM
BlazerLT's Avatar
AF -Advisor
Do a full tuneup and new oil change.
New Cap & Rotor
New Plugs
New Wires
New Fuel Filter
New Air Filter
New PCV Valve
Board can be resoldered. The solder connects tend to break.
Clicking sound? Does it actually work?
This is the sign of your cooling system needing flushing and filling with new coolant and a new NON AC DELCO radcap. Radcap does indeed need to be replaced.
How did you find this out?
O2 sensor just before the cat is shot and needs to bew replaced.
What code was it? Yes, cleaning it will fix it.
I don't understand why you purchased a truck without thoroughly testing it.
With these codes the engine will run pretty badly.
Is it running rough?
Old 01-04-2005, 11:36 AM
clariveros's Avatar
Also check the post for water in the dash, I have seen a problem similar to this before, they have the full description of this problem
Old 01-04-2005, 11:38 AM
BlazerLT's Avatar
AF -Advisor
Yea, it is the heater core having water in it.
New rad cap and a flush and fill fixes it.
Old 01-04-2005, 12:00 PM
jetaylorpb's Avatar
Thanks for the advice.
I did plan on doing the plugs, wires, cap,rotor, pcv, air myself. I think I will let the garage do the feul filter since I have never tinkered with a pressurized feul system.
Who would know how and what to solder? I play paintball and do accounting for work, never touched a solder before so I know I'm not going to do it. My neighbor works at an electric supply store and does ham radio etc, would he know what to solder by looking at it or am I better off buying a new board?
I think the rear wiper moved when I first got it but has since stopped.
OK on the cap, flush and fill.
Actually I assumed they unplugged it. I was suspicious when on start up the ses light never came on as it should. So I took it to Autozone last night and they got the codes for me.
The O2 sensor before the cat, is that on the manifold or is it on the exhaust pipes?
The 3rd code was the P1406 which is in the original post. Actually it runs great with lots of power, it is however only currently getting between 13-15 mpg.
If I can do a cap/rotor etc would cleaning the egr be manageable?
Old 01-04-2005, 12:06 PM
jetaylorpb's Avatar
As far as why I got it like this: It's a 97 with just 80k miles, maybe one scratch on it, LS but fully loaded with everything but leather which I hate, full off-road package (suspension, limited slip, skid plates) and I only paid $2000.
Oh, did I mention the dark green paint with black under the strip molding matches the anno job on my autococker paintball gun?
Old 01-04-2005, 04:06 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: New to me Blazer w/problems
Well, the light bulb could just be blown for the check engine light.
The O2 sensor is in the exhaust pip just before the cat. That is the one that does a lot of the fuel mixture measurements.
Clean and reinstall the EGR valve with a new gasket and that code should be fixed.
Old 01-05-2005, 09:07 AM
clariveros's Avatar
the fuel filter is an easy change, you just have be ready to have gas spill on you. it is located on the inside of the drivers side frame rail it takes about 15 minutes
Old 01-05-2005, 09:27 AM
jetaylorpb's Avatar
How do you depressurize the system and get it repressurized?
www.pubcrawling.org www.cockerownersgroup.com www.emrpaintball.com www.scenarioball.com www.atomicordnance.com
Old 01-05-2005, 09:35 AM
Mikado14 Mikado14 is offline
You can depressurize the system at the schrader valve on the fuel rack or you can just crack the lines at the fileter and wait for it to come down.
After the new filter is in, it will repressurize it self. You may have to turn the key off/on a couple times but it will take care of it self.
