Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-04-2005, 05:44 AM
Countrygalnlv Countrygalnlv is offline
Question 1993 Grand chrokee
I know someone that might be seeling a 1993 Jeep Grand Chrokee for $4000.00 aprox. Says only thing wrong with it is that it burns oil and you can smell it in the exghust. I allready own one 1989 Jeep Chrokee and its being a pain so b4 I buy another pain in the *ss I though Id get some opions anyone know what could be causeing this easiet fix to hardest most expensive fix?
Thanks
Old 01-04-2005, 07:27 AM
gtmud gtmud is offline
Re: 1993 Grand chrokee
If it is a Quadra-trac, full time 4x4, RUN away! There have been allot of problems with the T-case, then there is the front axle, seems the high milage GC's show alot of wear on the pinion shaft in the diff. As far as the oil leak, it could be either the valve seals, or more involved the rings on the pistons are starting to break down. I would NOT purchase this vehicle, these repairs can get pricy.
Old 01-04-2005, 07:29 AM
he says its not leaking oil its burning oil? Is it possible not to leak oil but to burn oil?
Old 01-04-2005, 08:04 AM
CTCarpenter CTCarpenter is offline
I bought a 1994 limited for 2800.00 with 110k recently, and it needed nothing except for a good cleaning. Wait for a better deal.
Old 01-04-2005, 09:36 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
well as for the quadra-trac, the VC are known to fail, use synthetic lube in it it will keep it from failing, and if the milage is high then chances are it's already been replaced, I paid $3500 for my 94 w/ 183 + (mint condition) and the VC was changed like 3,000 miles before I got it.
if you use synthetic fluids in the Transfer Case and routine maintenence then you shouldn't have to worry about it.
and like CT said 4G's is a lil high could find something a lil cheaper. I
