Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-04-2005, 02:45 AM
240fanatic 240fanatic is offline
fuel problem
When I start ny car, the rpm's go up to 2000 and then in a matter of seconds the rpm's dive down and the car dies almost like a stall. I was wonderiong if anyone knew what the problem is. I have asked some other people they said maybe injectors, fuel pump, or fuel filter. I was just wanted to get some more opinions. Thanx for any help.
Old 01-04-2005, 05:42 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: fuel problem
Turn the key to the "on" postition and listen for the fuel pump to run. Sounds like a humm. Check for kinks in the fuel line. Check your fuses. Clean the MAFS. When is the last time you replaced the fuel filter? Try that stuff.
And make sure the IAAV valve hose isn't blocked or anything. Its the larger one coming from the intake manifold and connecting to the intake.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
