Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-04-2005, 01:38 AM
Dicko1960 Dicko1960 is offline
Maxima 92 Ti Electical Problem
I have installed a new battery 2 days ago as the other died for no reason. Today I have had some electrical problems. eg. When the engine is at idle the climate control display disappears, when the engine speed is higher the display and other features work normally. The radio can come and go and if you put the hazard lights on the display can go out on the climate control but the display will stay on if the airconditioner is not operating and you are using fan only setting.
Does this mean the alternator is malfunctioning? (the battery light has not lit up on the instrument panel.)
How can I do a quick test on the alternator?
Old 01-04-2005, 02:05 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Maxima 92 Ti Electical Problem
Engine running, the alternator pumps voltage up. Take multimeter and compare engine on/off on battery terminals. Good battery 12.5V or more, engine off. Engine on, 13.8V to 14.25V depending if u have north/south specs regulator.
Battery is 1/1000 part of a system. Take a look and recondition u wirings and add alt grounding as it is not probably connected well enough.
See http://www.cardomain.com/memberpage/748507/1
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
