Old 01-03-2005, 08:42 PM
ozzfreak ozzfreak is offline
Crank angle sensor?
I am getting Code 4 (4 flashes) Crank angle sensor. Is it possible to replace this without replacing the distributor? And if so, where can I get one? What does it do anyway? Thanks.
Oz
Old 01-03-2005, 09:50 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Crank angle sensor?
Nope. You must replace the distributor. The CAS is a "part" of the distributor and there is no other way around it.
Sorry
Andrew
Old 01-03-2005, 09:52 PM
What does it do though?
Old 01-04-2005, 03:16 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
Re: Re: Crank angle sensor?
are you talking about the control module?
if so,it can be replaced.
In the process of B00stin my D
Old 01-04-2005, 05:13 PM
Just whatever code 4 means.
Oz
Old 01-04-2005, 08:14 PM
Re: Re: Re: Crank angle sensor?
he means the actual sensor in the distributor, and NO it cannot be replaced!
Old 01-05-2005, 05:35 PM
skotman's Avatar
skotman skotman is offline
i just recently dealt with this. the screw flew off the rotor and damaged the sensor somehow while i was driving to work one day. it was an easy fix... i just had to get a whole new distributor. after the engine warmed up, even with the screw back in the rotor properly, the engine light would come on, the rpms would slow, and when you tried to drive anywhere, the car would jerk-jerk-jERK like crazy and die a lot. i was only trying to get to the other side of my driveway, heh.
Old 01-05-2005, 05:45 PM
Well the wierd thing is, it runs fine. Except it overheats everytime i drive it because of the warped head. Has plenty of power just the water is going into the 2-3 cylinders. I can't get one plug out because of the sever warpage has one of the plugs stuck. I was just curious what the code was, thanks.
Oz
Old 01-05-2005, 06:56 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-06-2005, 03:47 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
i'd say screw the dizzy and throw a new motor in
Old 01-06-2005, 05:50 PM
I am within the month. I am going to go ahead and get a ZC from hmotorsonline. Wish me luck.
