Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 01-03-2005, 09:30 PM
batman81 batman81 is offline
neon gauge cluster install
does anyone know how to remove the needles to the tach, speedo, fuel gauge, and temp( all stock gauges). please help
Old 01-04-2005, 12:24 PM
m3kidds's Avatar
m3kidds m3kidds is offline
Send a message via AIM to m3kidds
Re: neon gauge cluster install
What kind of gauges are you installing? Usually the indiglo types are just overlays.
Uniquely Stock !!
Old 01-04-2005, 07:11 PM
Re: Re: neon gauge cluster install
Yeah they are overlays but there is a piece of plastic around them and the needles need to come off but I don't know how to remove either.(1998 accord automatic)
Old 01-04-2005, 08:16 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
I've never installed guages myself, but to my understanding, you're supposed to just turn the needle to point straight up in order to slip the new face behind it.
ECNATSISER AL AVIV
Old 01-05-2005, 08:40 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
You don't remove the needles. Removing the needles can screw up the calibration. You slip the needle through the hole in the middle of the overlays and then install the overlays that way. It takes more time and can be harder, but this is the proper way to do it. Where the hole in the overlay is that goes around the needle base, you slip the needle through this and move the overlays into postion this way, without touching the needles. The Speedo and Tach are pretty user, it's the dual gauges like the fuel/temp gauge on a civic ex/si that can be tricky.
The plastic you refer to is the plastic covering the gauges, correct? That removes with clips from the backside usually. You should see once the gauges are out of the car. Once that is off, install the gauges without removing the needles as mentioned above.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 01-06-2005, 09:22 PM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
the hx also has the dual gauges, fuel and temp. is there an easy way of getting that one on?
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
