Old 01-03-2005, 08:21 PM
arodg25's Avatar
arodg25 arodg25 is offline
engine problems need advice.
ok, i was driving home and after ripping it, my idle seemed really chuggy and my muffler sounded like put, put,put,put.... but when i got going say above 2000rpm it was fine, then it progresivly got worse for the next hour and finally overheated. now when i was checking it out just after i noticed the idle was screwy, i reved it up while it was out of gear and i blew a pretty big white cloud. so i thought damn it's the head gasket but when i started driving again the steam when away so now im not sure. could i have slipped a tooth on the cam shaft mabey?
anyway thanks for any help.
Old 01-03-2005, 08:30 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: engine problems need advice.
or... you could be blowing your headgasket out, if you can run a compression test and that'll let ya know... but running ruff and white smoke def. sounds like a headgasket...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-03-2005, 10:16 PM
rated- r rated- r is offline
Sure sounds like a blown head gasket. Check for water in the in the oil or oil in the coolant system. If theres nothing, then do a dye test.
Old 01-03-2005, 11:36 PM
arodg25's Avatar
i just pulled the plugs and the #2 (i think 2nd from the right) had oily coolant on it. damn it!!
Old 01-04-2005, 12:00 AM
arodg25's Avatar
does anybody know if i can use a d16a6 si head gasket on a d15b2 dx? cause i heard that people should use a gasket from a z6 (92-95 civic ex/si) or y8 (96-00 civic ex) on a d16a6 because there metal.
Old 01-04-2005, 07:29 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Re: engine problems need advice.
yes...all the dseries sohc head gaskets are the same (dunno about 01+ though?). Definitely use the 92-95 or 96-00 z6 or y8 gasket. Use nothing but the metal ones!!! Or, you'll be replacing that carbon metallic 88-91 gasket twice a year!
Believe it or not, when a Honda dealership replaces the head gasket on the older 88-91's they use the 92+ metal gaskets.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
