Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-03-2005, 07:56 PM
youngc youngc is offline
ding ding ding
Can somebody tell me where the door chime (key chime, warning chime) is located. It is the missing link on my 95 aurora. Everything works fine, except for this chime. I have been missing this for some time. Can somebody please help me. If anything, when you get in your cars next time, just give me a general area. Thanks in advance for the help.
Old 01-03-2005, 08:05 PM
GuMan GuMan is offline
Page 8A-76-3 indicates that the chime function is
performed by the instrument panel itself, and not
a seperate chime module. If all connections are
there, the only recommendation they keep spitting
out is to replace the instrument cluster... which
I would think is not worth the chime function.
By the looks of section 8C, you probably don't want
to get into it. It has you stripping the console to
the frame to get this out. Check your wiring
harnesses going to the instrument panel and make
sure they are all on as snug as you can reach.
Old 01-04-2005, 02:12 PM
Cool
Thanks for the help. I opened up the cluster and found a speaker. The speaker was disconnected. Whoever owned the car before me obviously disconnected this because of the problem they had with the Drvr info cntr. It always said "park brake set" which is normally accompanied with a chime. I replaced the ignition switch solving that problem. I now finally have the chime working. This is the first time the dic has worked since I have owned my aurora.
Old 01-04-2005, 08:42 PM
Isnibs's Avatar
Isnibs Isnibs is offline
youngc
Quote " I opened up the cluster and found a speaker."
Can you give us a write up on how to and where please.
1996 Aurora Black / grey
Old 01-05-2005, 07:45 AM
There are earlier posts on how to remove the instrument panel. Once you remove the instrument panel, have the side where you insert the light bulbs facing toward you (backside). Right behind the gas gage, there is a white plastic cover with a lot of holes on it. When you remove the two screws, it will reveal the multi-function chime. It is just a 1.5 inch speaker. I already put my dash back together, and can only go so far in depth. If you have further questions, just post another reply. Thanks
Old 01-05-2005, 07:12 PM
Isnibs's Avatar
Re: ding ding ding
Eggselent, great info thanks.
isnibs.
Old 04-08-2006, 08:37 AM
JBVOEXTREAM JBVOEXTREAM is offline
Re: ding ding ding
hey ive been having the same problem with my 95 aurora my driver info center isnt working either i had to pull the chime fuse from the fuse panel to stop all the noise. but anyway how much is the ignition switch cause i jus got the can and this is 1 of 3 things needed to be done so please get back to me
