Old 01-03-2005, 07:52 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
some help with Hallman Pro MBC
anyone here run a Hallman Pro with stock T-25?.
i just got mine today and installed it according to vfaq. i am just curious, because i have to turn the knob all the way up to the end (clockwise) on the valve to get 16.5psi with the stock soft spring provided. i am just wondering if it's the same with you.
06 Charger SRT-8 black.
Old 01-03-2005, 10:19 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: anyone with Hallman Pro MBC
boost leak?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-03-2005, 11:55 PM
i don't think so tho. one thing i did notice was when i first finished the install. i had the knob backed all the way out to lowest to start my test drive. and the boost was about 11psi with it all the way backed out (lowest boost). so i had to stop a couple times to make several turns clockwise and eventually get to my desired 16.5 psi. but now it seems the knob have hit the bottom. is that normal with the soft spring?
does that mean the factory T-25 have the wastgate actuator default at releasing the pressure to 11psi boost? or what does this mean.
Old 01-04-2005, 09:11 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: anyone with Hallman Pro MBC
Yep. The WG has a spring that basically regulates the lowest boost pressure possible. Do you have the stock BOV???? If so, that is likely your problem for maxing out at 16.5 psi. You really don't want to run the T-TooSmall anymore than 15 or 16psi.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 01-04-2005, 03:31 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If you have a boost leak (the stock BOV counts as one) and get 15psi, your turbo is most likely pushing the 20psi people recommend against, and it's leaking.
