Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-03-2005, 05:01 PM
Scheetz Scheetz is offline
Exclamation 2001 LS Trunk Release Issues
I've been trying to install a remote starter into my 2001 LS and am having some issues with the trunk release. Since I purchased the car used about 6 months ago the release button in the cab hasn't worked, but the remotes always work so I know it isn't a solenoid. So now I am trying to hookup the aftermarket remotes and I can't get them to work. All wiring diagrams I have come across say that it requires a negative pulse to a white wire either behind the switch or in the REM in the trunk. There isn't a white wire on the switch, only a black/white and black/green, but I can't get either of them to do anything, and I can't even locate the white wire in the REM. Any suggestions, with getting the switch to work or the aftermarket remotes?
Old 01-17-2005, 11:01 PM
fry628's Avatar
fry628 fry628 is offline
Re: 2001 LS Trunk Release Issues
I've seen this all the time so if this is basic knowledge to you I apologize in advance. There is a button in the glove box that gets pressed by accident and is very hard to see unless you are looking for it. It's a way to lock your trunk if it's parked by an attendant.
Certified Ford tech for 10 years
