Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-03-2005, 04:59 PM
carot carot is offline
Thumbs up 91 caprice classic
Come on guys surely there is somebody out who has removed the top dashpad in a caprice classic
You all post replies of one kind or another is there nobody out there that can help me
Thanks/Scouse.
Old 01-04-2005, 03:17 AM
DevilDog83 DevilDog83 is offline
Re: 91 caprice classic
Remove the console panels and take out the screws from under the dash
Old 01-04-2005, 11:46 AM
Console Panels (please explain) & How.
screws from under dash? (I want to take the top pad off not the dash.Or do you mean the screws under dash pad.
Thanks Scouse
Old 01-05-2005, 02:03 AM
Sorry meant instrument panels... ie the spedometer and guages panel cover... should unscrew and yes when you take that off and get behind it 7you will see the dash pad screws
Old 01-05-2005, 03:11 PM
burnM's Avatar
burnM burnM is offline
On the '91, to get to the dash pad you have to remove pretty much the whole facia of the dash.
Start underneath the dash, and remove the panels that cover up the wiring (kick panels). Mine doesn't have them, maybe just the driver's side.
Then you have to remove the piece underneath the steering column.
The entire piece that goes across the guages, radio, heater, right over to the glovebox has to be removed.
The woodgrain piece over the glovebox just pulls off, there is a screw underneath that that has to come off. (open the glovebox to remove it)
The only good news about all of this, is that the light switch, radio, guages, etc, don't get disturbed (you don't have to remove them).
After all of that is out of the way, you should be able to get to the scews that hold the dash pad in place.
They should all be at the front edge of the dash.
After those screws are removed, you should be able to pull the dash pad up, and toward you. It should be held at the base of the windsheild with clips, rather than screws. You may have to pull hard, but it will come out.
It seems like a pain in the a** to have to remove everything, but, once you've done it, it's cake to do it again.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
