Old 01-03-2005, 02:00 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
Unhappy help with radiatior fan
i know this is a n00b question, but i just want to know what i am doing before i do it. My radiatior fan does not come on so i want to have it switched from inside of the car, i have a toggle switch and rolls of various sized wire lying around, what size wire should i use and whitch wire goes where from the fan?
appreciate your help
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 01-03-2005, 03:17 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: help with radiatior fan
Fans draw enough current that its best to use a relay. That way you can use a smaller gauge wire to run to the switch and less chance of the switch burning out. I can throw up a wiriging diagram if you dont know how to do this. But I would recomend that you just get it working the way its supposed to. Check the factory relay, its mounted next to the right side (passenger) headlight. More than likely its either the relay or the sensor. I'm not quiet sure where the sensor is at, but I'm sure you can look it up in Helms.
Old 01-03-2005, 03:31 PM
jhmcrx's Avatar
ok i have my manaul on hand, first if the relay is that black rectangle its grounded to the side. 2nd when you say sensor whiche one do you mean?
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
Old 01-03-2005, 06:45 PM
jhmcrx's Avatar
ahh forget it, how can i safely switch the fan?
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
Old 01-03-2005, 07:30 PM
Forunn Daberator
This is the bottom side of your standard 30 amp relay. (86) will be ran to your switch (87) will be wired to the battery, using the same gauge wire that is on the fan leads, I'd use 12g just to be on the safe side (30) will be wired to fan possative (85) will be grounded. You will also need to ground your negative wire coming off the fan.
I'm not sure what sensor it is, but one of the temp sensors controles the fans. Maby someone else on here can help you with that one. Also insted of hooking it to a switch, you could wiring it to your iggnition so that it will automaticly come on when the car is started and go off when the car is off. You can do this by runing (86) to the fuse panel and tieing it into something that only comes on when the car is started, such as the radio.
Old 01-04-2005, 01:34 AM
jhmcrx's Avatar
ok, thanks for your help!
and this is werid you actually didn't know something
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
Old 01-04-2005, 07:23 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
simple....get a 2 prong switch from autoblown. splice it into the ground wire of the fan...done. you don't need to wire in any relay....been runnin' mine for over 7 months now.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-04-2005, 07:56 PM
jhmcrx's Avatar
yah, i guess that works too but i used silentchamber's method and it works great, anyway thanks for replyin!
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
Old 01-04-2005, 09:05 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: Re: help with radiatior fan
yeah that way will work... but its not right... if you are going to do it, do it proper...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-05-2005, 07:40 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
My wiring from the harness is f**ked so I wired mine up to the ignition. All you have to do is ground it good to the chassis and use a 20a fuse on the positive wire and you're good to go...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
