Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 01-03-2005, 01:04 PM
riff22 riff22 is offline
turbo in n/a?
will the tsi turbo motor fit in a non turbo car like a eclipse rs with out any modding? i totalled my talon and im trying to find a car with a blown motor.
Old 01-03-2005, 01:12 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
maybe you should try searching the board.....
http://www.automotiveforums.com/vbul...d.php?t=200222
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-04-2005, 12:38 PM
ace_33_ryan ace_33_ryan is offline
Re: turbo in n/a?
So do i if anyone knows where i can get either a stock gst engine or a 4G63t engine please let me know
Old 01-04-2005, 12:44 PM
george536's Avatar
george536 george536 is offline
Re: turbo in n/a?
What engine can I swap into my GS/RS ? - ashah000
The only engine that can be directly swaped is the one that is in there right now (the 420a).
You can swap a GS-T engine into the car but it would be extremely difficult and costly.
Here are the costs (from 2gnt)
1. 4G63 turbo engine (stock) $1500
2. transmission (stock GS-T FWD) $500
3. wiring harness for engine $300
4. 4G63 ECU (stock) $300
5. shift linkage $200
6. custom engine mounts $200
7. chassis cross member $100
8. complete exhaust $200
9. intercooler, turbo, related parts $500
10. boost gauge/fuel filter, etc $300
11. Installation $1500
Total - $5600
You can also swap in a 2.4L from a Dodge Stratus/PT cruiser. This is easier than the GS-T swap, however it does require some custom faberication. Also it would be backwards (the header would be on the firewall side)
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-10-2005, 01:42 PM
Re: turbo in n/a?
well i have the motor and everything from the tsi i think it would be easier to swap then fix mine. so all i need is the cross member, and mounts. what about the radiator core support is the radiator the same??
Old 01-10-2005, 02:14 PM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
To answer your question clearly. NO the Talon TSI motor(4G63T) will not fit a non turbo eclipse (420a) The turbo talon motor is the same as the turbo eclipse motor. It will require way too much work and way too much money. But if you got it then go for it. LoL
1999 Eclipse Spyder GST-Race
-DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous
