I'm getting a periodic rattle sound coming from under the hood. I can sit in neutral, no noise. I put it into drive (automatic) and I hear a rattle noise that goes for a couple seconds, cuts out for a few seconds, comes back on. It seems to happen less when I have the vents/air/defrost off. I replaced the belt with one of those Gatorback non-stretch no-squeal belts. It seems to be working well.
I checked the forums out and the closest I came to was the timing belt, but that appears to be a constant noise. This sounds more like a pulley might be rattling out a bearing in the cooling fan went out? I'm going to check to make sure everything is tight under the hood tonight. With the front brakes, ABS, I sometimes, maybe 1 out of 100 brakes, I get an awkward pulusing and weak braking. If I let off the brake, push it down again it goes away. Any thoughts? Anyone having problems with the front end ball joints or odd clicking when doing sharp turns (into a parking space or U-Turn)? I hear the ball joints tend to go out every 33,000 miles or so, but I just get a click/clack once in a while. I've had it checked out twice at shops (never the dealer) and they've told me it was an expected noise. Thanks for the help in advance. |
Re: 1999 3.9L Engine noise/Braking ?
There was a recall for ball joints going bad on Dakotas between 97-01 (also for Durangos). Might wanna go to the dealer or a service shop and get those ball joints looked at ASAP.
Check your alternator for the rattle, that's always been a periodic problem for me.
I'm amazed at the level of misinformation on some of these posts. The recall is for 2000-2003.5 Dakotas and Durangos. The ball jounts would NOT cause a rattle in the engine compartment, especially with the truck sitting still.
2006 Wrangler Unlimited |
had to replace the ball joints(upper and lower) at my own expense, that caused a rattle over bumps not idling. My idling rattle was from bad fan. fan now sounds like an airplane.....hmmmm
sorry, have 99 myself
Re: Re: 1999 3.9L Engine noise/Braking ?
