Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-03-2005, 09:56 AM
clariveros's Avatar
clariveros clariveros is offline
Horn Not working
Hello,
My gf drives a 1999 neon, and i do not know how long this has been going on but the horn does not work. I replaced the relay, and it still does not work i am begining to think that it is something else like the actual switch on the steering wheel. any suggestions on other places to look?
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
Old 01-11-2005, 09:58 AM
1quickneon 1quickneon is offline
Have you checked the horn fuse in the fuse box under the hood? That was my problem when my horn didnt work. If the fuse isnt blown.,see if the connection to the horn is still connected. On my 96 neon the horn is behind the left fender.
Old 01-11-2005, 03:38 PM
clariveros's Avatar
Re: Horn Not working
hey thanks for the advice, I will do that tonight,
is the fuse next in the same box as the relay?
Old 01-18-2005, 09:11 PM
Its in the fuse box under the hood it might be with the relay im not to sure. I know there are large fuses in that box though. The horn is like a 5 or 10 amp fuse its one of the mini fuses. hope this helps
