Old 01-03-2005, 10:12 AM
bandera bandera is offline
My first shot at stripping paint #@%$&?/>
I have modified several diecast, but they have all remained original paint. Is there a faster way to get that stuff off. Tried Castrol Super Clean for two days, used oven cleaner overnight with a fresh shot in the morning, Greased Lightning and the last little bit of brake fluid I had. Most of the undersides came off easily, but the outside parts with a good shine of them must need to be dymonitted off. I have a deadline to meet. HELP!
Old 01-03-2005, 11:41 AM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: My first shot at stripping paint #@%$&?/>
So you want to strip paint......how about some paint stripper?
Go to wal-mart and get a can of paint stripper, make sure the temp where you're working is pretty warm and take that stuff off. Its not rocket science.
Old 01-03-2005, 01:27 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Take all the plastic off, and use Jasco.
-Mike
Old 01-03-2005, 10:38 PM
Rubberband Man's Avatar
Rubberband Man Rubberband Man is offline
Send a message via AIM to Rubberband Man
Well ... you could do what I do, get a dremel and a tough grit sand attachement and go to town on the car. And then after words sand it down ALOT cause the metal definately wont be even. Probably not the best method, but eh whatever, I tried it, doesnt look half bad.
Old 01-04-2005, 05:30 AM
Found some paint stripper in the garage (I forgot I had). Took off all the paint in about 15 minutes. Thanks for all of the tips!
Old 01-04-2005, 09:05 AM
G35XAndTrailBlazer's Avatar
G35XAndTrailBlazer G35XAndTrailBlazer is offline
Banned
Send a message via AIM to G35XAndTrailBlazer
You could have heated the paint up with a torch, and then jsut crack it off.
Old 01-04-2005, 11:17 AM
crday98 crday98 is offline
if your going to strip paint, go to walmart and get a can of "aircraft stripper" it will work better than any stripper out there and it is pretty cheap.just make sure not to get it on any plastic peices because it will melt it. also, be sure to follow all the safety precautions labled on the can as it is very potent stuff.
Old 01-04-2005, 11:37 AM
Gafoto's Avatar
Re: Re: My first shot at stripping paint #@%$&?/>
Don't use heat to remove paint unless you have to, some diecasts are too weak to hold up under heat.
Old 01-04-2005, 05:19 PM
Banned
Well, he may have a strong model lol i did that to one of my cars and it worked lol
Old 01-06-2005, 10:53 PM
brad_26 brad_26 is offline
Send a message via AIM to brad_26 Send a message via Yahoo to brad_26
um i got a sand blaster lol that works really good and makes the car really clean
