Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 01-03-2005, 04:09 AM
jmur61 jmur61 is offline
Unhappy Digital Cluster turns off at nightfall
My 84 Vette Digital Cluster goes black completely at nightfall and lights up at day break. A few nights back it did a number on me that nearly startled me; the two signal lights lit up solid for a few minutes than went black again. Besides sending it for repair, is there anything I can try to fix it?
Old 01-03-2005, 09:09 AM
hexonxonx2000 hexonxonx2000 is offline
My wife's '84 does the same thing.. sort of... It actually does it intermittantly... both the turn signals and high beams indicator come on... I've been told by several people to just send it in and have it rebuilt ... I think Ecklers does it ...
Sorry Couldn't help more than that....
Old 01-03-2005, 05:56 PM
DannyC4 DannyC4 is offline
my 84 does that too, once in a while, when I turn the key on the ignition switch, both the turn signals and the high beams indicator turn on, it goes back to normal after I teach my dash a few karate lessons, LOL! Good luck with yours.
Old 01-07-2005, 06:39 AM
Re: Digital Cluster turns off at nightfall
hexonxonx2000 & DannyC4,
Thank you both for your replies.
I am glad to know I am not alone with this problem.
I tried something very silly yesterday...I bought an LED and placed it inside the cluster, connected the wires to the live headlight wire and to the chassis, now when I turn on the headlights, the LED turns on. It helped a little. I can now see the digits but dim; as opposed to nothing.
I also noticed there is small square opening on the cluster bezel which I believe is the LED night sensor, I will open the cluster again and trace the circuit of that LED.
Old 01-08-2005, 05:00 AM
Good luck with that man!
Old 01-10-2005, 01:31 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
eh..... cant say as i ever ran into that problem. sounds a bit like a loose weld on the circut board that is making and breaking contact. you can probly easily track the problem and resoder it yourself, but its kinda a hit or miss thing, you might be better off sending it out to be repaired.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-10-2005, 09:38 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
I realize that this is an old post, but this would seem to be related to your headlamp system. When you turn on your headlamps, your instrument panel is supposed to dim. (You don't need as much light to see it after dark) Be sure that your panel dimmer is turned up all the way, maybe they are just dimming, but you have them turned down so much that they appear to be out.
I'm not sure what automatically dims your panel when you turn your headlamps on. It could be the panel dimming switch, the headlamp switch or it could be the ecm. I doubt if the problem is in the panel itself.
Only my two cents
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 02-10-2005, 09:41 AM
Thumbs up Re: Digital Cluster turns off at nightfall
Only my two cents
-slacker
This is not a related issue ... the lights on the dash do not dim... they completly shut off... It's a common problem and I will send out the cluster for repair to fix the problem... Thanks though...
Old 02-10-2005, 03:35 PM
slacker_53's Avatar
Glad you've got a handle on the problem. I don't suppose getting the cluster fixed is going to be inexpensive.
I hope that fixes you up.
-slacker
Old 02-11-2005, 11:39 PM
Thanks for your replies.
Where would be a good place to send my cluster for repair?
This is my only transportation and would like a fast turn-around.
Old 02-12-2005, 07:31 PM
try ecklers, but I dont know how fast you gonna get it back. Good luck man!
