I have no heat blowing through the front but only the back, I checked the fuse under the driver panel but seem good , curious could somebody tell me where I can locate the front blower motor , iis it in the engine area and where // ?? Please and Thank you its getting cold here in Ontario with no heat
The blower for the front is right behind the glove box on my '96 Winny.
The blend doors are vacuum actuated so you may want to check the vacuum lines to the doors. I believe the blend doors are supposed to default to the defrost setting if they lose vacuum. Also wonder if there is warm coolant getting to the front heater core. Must be warm coolant getting to the back if the back is warm. |
Re: 96 windstar No heat from vents
The Blower Motor Is Located Behind The Glovebox Up Above And Left Of The Passenger Kick Panely, Your Blower Motor May Have Be Disconnected If Some One Had Accedentaly Kicked It, Happens Frequently, If It Is Connected U Can Check For Power, If U Have Power, Check Resistance Of The Blower Motor, If It Read Ofl, You May Have A Bad Blower Motor Resistor, Being In Ontario, It Could Have Got Wet From Moisture And Rusted, Very Common For Ford
I checked the Front Blower to see if it was disconnected and it wasn't , could you please tell me where to find the
Bad Blower Motor Resistor??The van has 2 Blower motors one for the front and one back behind the driver seat , Thanks for showing me where the blower motor was located |
each blower has its own resistor...should be right on the blower motor
