Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-02-2005, 09:36 PM
happygilmore79 happygilmore79 is offline
poor runnin' 5.0 LX convt.
Hello, we're new here my 16yr old has a 92 5.0 LX convt. w/auto.
we had a blown head gasket so we had both heads redone plus put in new timing gears & chain new water pump.new plugs,wires,cap and rotor. And it runs like s#@ t... maybe a injector ?? if so hows the easist
way to check ??? we have lots of time. car is put up for the winter.
thanks for any help....
Old 01-04-2005, 12:17 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: poor runnin' 5.0 LX convt.
Stuck injectors will usually (but not always) tick.
You're dead sure you got the timing correct and the firing order correct (I myself have a bad tendency to think the dist. turns the other way)?
beg/borrow/buy a fuel pressure tester, make sure the pump is good.
Run the engine until it starts reading the 02 sensors, then kill it. Pull the plugs, if you have a stuck injector it's plug will be white (lean)and all the others on that bank will be black (rich).
also, does it have the stock converters? Did you get any smoke when the HG blew? Cats don't live long after getting antifreeze in them....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 01-07-2005, 09:37 PM
matt17 matt17 is offline
need more info on how it's running?rich/lean,no power,popping,back firing?
Old 01-12-2005, 06:15 PM
matt17
The car doesn't have much power, and sounds like it's not runnin' on all
the cyl's.(missing ) Runs better @ higher RPM's.
Hope this helps you,help us. Thanks
