Old 01-02-2005, 08:38 PM
tac89 tac89 is offline
Noise Under Battery
I have a 2001 Ford Taurus. There is a box under the battery (sounds like a fan) that is running and will not cut off. What is it and how do I fix it?
Old 01-03-2005, 04:20 PM
KimMG KimMG is offline
AF - Advisor
Re: Noise Under Battery
Does it stop running when you disconnect the battery? What is it connected to? Look on a wiring diagram to see if it can be identified. Can you post a picture?
Old 01-03-2005, 07:34 PM
It does cut off when battery is unhooked. I left battery unhooked all night and it stopped. Was told it sounded like the ABS pump. It is a square metal box directly under battery.
Old 01-04-2005, 03:38 AM
AF - Advisor
Do you have a local Midas or some other brake shop that does free brake inspections?
Old 01-17-2005, 09:54 AM
JVH JVH is offline
Noise under battery
You need to replace the $75 relay that controls the electric air pump for excess air to the catalyst. It is mounted to a bracket on the lower left front frame rail that also holds the air pump itself. Removing the bracket is a real PITA is lying on the garage floor...not so bad on a lift. Around 1 hour labor.
JVH
