Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 01-02-2005, 08:32 PM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
got a nice deal with question!
got a deal on a stock s4 turbo, exhaust manifold , and starion FMIC, 550cc turbo II injectors and ecu. but have't bought it yet , price for everything is $200 .
question is can i make my S4 N/A - tubo with just 550cc injectors , ECU , turbo , turbo exhaust manifold and custom made charge pipes and use the N/A intake manifold??
i know iknow is posible, but i am not planing on covering it to Turbo II , just a RX7 turbo. no TurboII tranny driveshaft , rear end etc etc.
I was planning on keeping the N/A intake manifold, and just do some custom crazy charge pipes, and is gonna be kinda diffincult cuz of the aux ports, I have remove that already so i got the clearence on the exhaust mani.
Another thing is the high compression on the N/A engine but i am also planing in just keeping low boost.
SOO what yo think??
P.S I am planning this because of such of a deal .
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 01-02-2005, 11:40 PM
RedFC3S's Avatar
RedFC3S RedFC3S is offline
Re: got a nice deal with question!
you cant turbo the N/A motor, that is all
1990 RX-7 Turbo II, Streetport, 62-1 Ball Bearing Turbo, FMIC, R.E. Amemiya exhaust, Haltech E6K, GReddy gauges, Apex-i AVC-R, and much much more
Under a complete Time Attack/Drift makeover
Old 01-03-2005, 06:42 AM
fcdriver fcdriver is offline
You can turbo a 6 port but it isn't going to be as reliable as a 4 port. A few people have gone with the N/A lower intake manifold and used a spacer on the turbo manifold but notched their frame to make room for the turbo.
The best way I've seen is using the turbo intake manifolds and exhaust manifold. You have to cut part of the lower turbo intake manifold to allow for the 6 port, use a N/A lower intake manifold gasket for a guide to grind. You'll also need the front engine cover for the oil and coolant lines for the turbo with either N/A intakes or turbo intakes.
You can run 10-12psi on it with the right mods, fuel pump, injectors, emc or an adjustable fuel pressure regulator.
I've got a few sites saved that give a better description on the process but I'll have to dig them up later
Old 01-03-2005, 09:13 AM
Look at the "What turbo kits can I add to my non turbo RX-7?" here;http://www.rx7club.com/showthread.php?t=181219, and a few more here;http://www.nopistons.com/forums/inde...howtopic=12743
Old 01-03-2005, 03:17 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
you can turbocharge any engine.
maybe wiring the aux ports shut is a good idea?
oh, and if you plan on making more than stock hp you better get t2 drivetrain parts if you know whats good for you.
also, i'm not sure but turbo and n/a harnesses are different.
RX-7 TII
Old 01-03-2005, 03:45 PM
ShortyDTP's Avatar
150 bucks!! this is sooo much temptation!! , he just want to get rid of it!!.
does anybody have TII upper and lower intake manifolds asap??????
Jose Mendoza
Old 01-03-2005, 05:20 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
is the exhaust manifoil cracked ?
if not, buy it anyway
Old 01-04-2005, 12:39 AM
ShortyDTP's Avatar
nope everything is pretty good, it came off out a 87 TII with 71k miles.
I am gonna buy it off , and i am gonna do my crazy shit see what i come out with.... prolly blow it up , but hey that's how you learn.
I am getting a settelment in march , out of a accident I had a while back. so that's when i get my Complete TII. hoo ray!
Jose Mendoza
Old 01-04-2005, 05:00 PM
drftk1d's Avatar
good luck man.
not an easy project.
RX-7 TII
Old 01-05-2005, 01:06 AM
ShortyDTP's Avatar
W3rd!!!
Maybe I'll be back with another thread and maybe a sticky ........ : "5 Reasons For Not Turbocharching You N/A FC." LOL
Jose Mendoza
Old 01-05-2005, 02:05 AM
It's not too bad just be easy on the trans or it'll bite you in the end. I had thoughts of doing the same before I bought my T2 engine and from all the reading I did it didn't look to be very hard at all.
