Old 01-02-2005, 08:23 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
Angry annoying intake
ok ever since i swaped to mpfi, my intake makes the most annoying whistle! it starts a little before 2k rpms, im not sure how long it will go. it freakin sounds like im walking thu a football field durring practice, i dont understand how it gets that loud at such low rpms so how can i shut it up? oh and another thing since i did the swap the exhaust is reealy smokey, i put some oil burning additive and fuel injector cleaner
just now but i dont know if it will do anything, any of you guys who done the swap had this problem?
Appreciate your help.
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 01-02-2005, 09:15 PM
dxhatchback dxhatchback is offline
Re: annoying intake
that sound will be there forever.. its from the TB suckin in air threw a little crack... get a CAI and it will go away...
and your engine is prolly junk... smoke means burning oil.. either rings (check by comp. check and leakdown test) or maybe its suckin threw the valve guides... if you only see smoke when you let off the gas at say 6500 RPM to shift, then its prolly in the head
Travis
HONDA is the BOMB!
Old 01-02-2005, 09:21 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
what colour smoke?
Old 01-02-2005, 09:49 PM
jhmcrx's Avatar
Re: annoying intake
no my motor is good it has around 43k miles, i just swaped that like 2 moths ago and it wasent doing it with dpfi, the smoke is white.
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
Old 01-02-2005, 10:26 PM
1PhatCX's Avatar
white smoke usually means a headgasket, or burning brake fluid. my car burns brake fluid and it smokes white, but only when i hammer the brakes really hard, or pump them, or when i take a really sharp corner fast lol
Old 01-02-2005, 11:55 PM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
Re: annoying intake
YOUR CAR BURNS BRAKE FLUID!?!?!?!?
are u sure... if ur burning BRAKE FLUID u fuck something up when u swaped ur motor
Old 01-03-2005, 09:46 AM
1PhatCX's Avatar
i didnt fuck nothing up, did it with the d15 as well, its the seal on the back of the master thats shot, so its leaking into the booster, and since the boosters vaccum assisted and connected to the intake, when lots of force is applied or if it finds its way toward that hose it gets sucked up and goes into the intake manifold, i know this because i plugged off the line pumped the brakes and nothing came out, put it back on, did the same thing and it smoked out my neighbourhood
Old 01-03-2005, 11:47 AM
]{iwi's Avatar
Registered User
Re: annoying intake
yeah i thought about that after i posted
dont u work at a parts store either way fix that shit
Old 01-03-2005, 12:23 PM
1PhatCX's Avatar
yep i do, but i also have an integra MC and booster sittin in ny garage along with the rear discs, just waitin for a prop valve to use it all
