engine swap d15 to b18
Ok, If I was to buy a smashed teg with a 1.8 in it, would I have everything that i would need to do the swap from 1.5 to the 1.8 besides the motor mounts?
Re: engine swap d15 to b18
no, i dont know much about motor swaps at all, but i do know lots of people ask Similar questions on this forum,
im sure you will find your answers quick if you look ![]() good luck!
1988 CRX DX MODS: Garrett T28 turbo 450cc DSM injectors TurboEdit STD manifold W/adaptor plate dsm bov stealthemodeperformance.com oil line's Tsudo cat back basic hi flow cat front tower bar, rear tie bar short throw shifter and other small stuff |
no you will have to convert to mpfi. and it also depends what year is the teg. the better year would be 90-91. even though it has 10 less hp it is more plug and play. cause the 92-93 is obd1 and unless you want to change the harness or dizzi 02 sensor,and ecu etc
thanks alot for the help. i mostly wanted to know if i would need motor mounts i knew about the mpfi. I know where there is a smashed 90 teg im thinking about buying it now they want 400 bucks
yes...don't listen to them...
a 90 teg has EVERYTHING you need to drop a b18 in ur car EXCEPT... the aftermarket mounts and linkage... do it!!! for mpfi....you just convert to it using the teg intake manifold, dizzy and just do the normal mpfi wiring...
