Old 01-02-2005, 07:46 PM
havok94's Avatar
havok94 havok94 is offline
2001 Spark Plug Removal
Ok, I got a 2001 Grand Am (obviously) 2.4L Twin Cam the problem is, the plugs need replaced, BUT i can't figure out how to get to them. How would I go about getting to them? Do I need to remove the cover between the cams?
Old 01-02-2005, 09:14 PM
devolljs devolljs is offline
Re: 2001 Spark Plug Removal
Yes, remove the cover between the cams. There will be a set of plug grommets, remove them and there will be your spark plugs. Make sure all the electrodes line up when you put it back together, because if I remember right, there is an aluminum fuel line that is in the way. You have to snake the cover in under this line.
Old 01-03-2005, 09:41 AM
havok94's Avatar
thank you very much.
