Old 01-02-2005, 07:20 PM
phatboi phatboi is offline
86 blazer heater fan
86 blazer has no power to the fan motor or the switch
the fan works I tested it
I have heard of a resistor box or relay some where, but don'y know where to look to test them
Old 01-02-2005, 09:16 PM
Mikado14 Mikado14 is offline
Re: 86 blazer heater fan
I will state the obvious first, have you checked your fuse?
Old 01-02-2005, 09:39 PM
ricksza's Avatar
ricksza ricksza is offline
Power goes from the fuses, to the switch, to the resistor, to the motor.
Start at the beginning
Old 01-03-2005, 11:09 AM
Re: Re: 86 blazer heater fan
ok so if I have power at the fuse and not at the switch then what ??
which wire on the switch will have power
Old 01-03-2005, 12:39 PM
ricksza's Avatar
The closest wiring diagram I have is for 1989 which should be close. The blower switch gets its power on the brown/white tracer wire from the mode select switch which gets its power on the brown wire from the fuse box.
