Old 01-02-2005, 07:46 PM
markjvoss markjvoss is offline
Angry 99 Cherokee Strange issue!
I have a 1999 Jeep Cherokee. About 2 weeks ago the AIRBAG light came on, the horn stopped working, the hazards stopped working, the no seat belt warning doesnt work, and the cruise control does not work. Everything else on the jeep work fine!
Any help is greatly appricated!
Mark
Old 01-02-2005, 08:17 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
check your fuses, I bet you will find one that is blown!
Old 01-02-2005, 08:33 PM
Angry Fuses...
Checked all the fuses, replaced all. No good yet!
Old 02-22-2005, 09:35 PM
tc4125 tc4125 is offline
Re: Fuses...
Same on my 2000 ...l no blown fuses in cabin nor @ PDP under hood ... servo, vaccum, all ok. no cruise light either. would seem to be fuse but all checked ok
Old 03-09-2005, 08:14 PM
bayouwolf's Avatar
bayouwolf bayouwolf is offline
Re: 99 Cherokee Strange issue!
Check the ecm behind the passenger side kick panel..You may have a loose or weak connection. Also check for a bad connection behind the fuse panel.
Old 03-11-2005, 06:52 AM
SteveB05's Avatar
SteveB05 SteveB05 is offline
Do the turn signals work? It looks like they all share a junction connector under the dash.
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
Old 06-09-2005, 10:19 AM
skate14 skate14 is offline
Faulty airbag control module,....check with your dealer to replace for free..97-2000 cherokee's are affected. Recall#860
http://www.recall-warnings.com/nhtsa...nt-00V105.html
Old 06-10-2005, 10:11 PM
sklater sklater is offline
Send a message via MSN to sklater
Do I have to take it to the dealer where I bought my jeep from for the fix of the airbag light? I bought it from a used dealer and that is why I ask. Also, even though it is 2005, will they still fix it for free? And one more question, if it turns out to be something other than what the recall is for, will I suddenly be charged to have it fixed?
thanx a bunch
jeff
Old 06-11-2005, 11:33 AM
Re: Re: 99 Cherokee Strange issue!
thanx a bunch
I don't know about it being a recall for the 2005, just '97-2000 as far as I know....Your Dealer will not fix anything on your car unless you give specific authorization for it. Recall items must be fixed at a authorized jeep dealer.
Old 06-11-2005, 01:09 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Re: Re: 99 Cherokee Strange issue!
The air bag module recall is just to relocate it to a higher position in the car (the center console area) so it will not be affected when crossing water (creeks, etc.).
MarkJVoss has indicated he has other electrical problems also, which may or may not be related.
I would have a good dealer techician test it for you. They have a computer to check that stuff (It is not available on the "outside"). It goes onto the diagnostic link.
Old 06-11-2005, 03:41 PM
Re: Re: Re: Re: 99 Cherokee Strange issue!
mine was corroded, the dealer cleaned up and replaced and all has been well since.. I hope it works for him/her as well...good luck with it.
