Old 01-02-2005, 05:58 PM
manyodas88 manyodas88 is offline
oil pump noise
we have a 94 s-15 with the 4.3. 60k miles i could hear a whirring noise under te engine and traced it to the bottom of the oil pan.i had just changed the oil and thought that it just had some trapped air from the remote lines draining back but it seems to continue to do this. i was hoping that it was just some trapped air in the oil pump that would work itself out. anyone have trouble with this or ideas? thanks
Old 01-02-2005, 06:49 PM
tom3 tom3 is offline
Re: oil pump noise
Oil pump is all enclosed, a couple gears running together, can't imagine that type of noise from that. I'd suspect the front pump on the automatic trans. Be sure it's full. Or maybe the power steering pump, but that would be more forward.
Old 01-02-2005, 08:31 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: oil pump noise
Could also be whirring from bearings just carrying accoustically...(sic?)
Old 01-02-2005, 09:20 PM
Mikado14 Mikado14 is offline
Re: oil pump noise
Check the shaft on your distributor. Any slop in the bearings will telescope the noise into the hollow of the oil pan.
Old 01-03-2005, 10:05 AM
Fireplug Fireplug is offline
Re: oil pump noise
Never heard of a oil pump making noise. Did you check the trans for this noise?? like the trans front pump
