Old 01-02-2005, 05:15 PM
chasfish chasfish is offline
Transmission Flush
I've had some bad experiences apparently related to transmission flushes. Wondered if any one else has too.
In March 1993, had 1988 Buick Century wagon (165000 miles) tranny flushed. Had done it two or three times in past every 40000 or so. Tranny locked up in park after mechanic ran through grears one time. Cost of repair> 1700.00. I think some kind of pump failed. Not sure.
Last week, had 1993 Buick Cent. wagon (113000 miles) tranny flushed. Had done previouosly at 84000. This time, a couple days later, tranny wouldn't go into reverse or in any of the drive gears for a few minutes. Then, it started to work. HAven't had tranny looked at yet, so I don't know what's involved here.
Any one have similar problems related to flushes??
ty.....chuck
Old 01-02-2005, 06:34 PM
Autopro Autopro is offline
Welcome to the forum, I havn't had this type of problem before. But I recommend you have it looked at asap. It's important to repair a problem as soon as it happens because 9 times out of 10 when letting a problem go and not having it checked or repaired immediately, the problem gets worse and the cost to repair it usually goes up as well.
I would go back to the place that did the flush and explain the situation to them and see what they can do. You should have some kind of guarantee.
Autopro,
Old 01-03-2005, 12:45 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Transmission Flush
yes, I don't recommend transmission powerflushes in any car, they tend to send scrapnel through the transmission doing more harm than good. I also only recommend fluid to be changed if the old fluid is brown or smells burnt.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 01-04-2005, 01:24 PM
I checked. Mechanic claims 'first time ever happened'. No help. Have appt. tomorrow at tranny place. Lee Miles Tran.
Autopro,
Old 01-04-2005, 01:26 PM
Re: Re: Transmission Flush
Is there any solid documentaiton anywhere of this happening to people and their cars? I can't be only one. I think mechanic said it was a Wynn (sp) process/machine of some kind.
Old 01-04-2005, 05:02 PM
danny350 danny350 is offline
Threre's really no way to prove that the flush did the damage. It's logical to assume it could have, but you might just have shitty luck. And a older tranny failing at 165 000 miles isn't very good, but it's not that bad either.
Old 01-05-2005, 01:53 PM
I believe you, but do you have any 'proof'??
Old 01-05-2005, 02:00 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Sounds to me like the transmissions probably just failed due to age and mileage it just happened to coincide with your flush. It is a good idea to change your fluid at the recommended intervals, for one if you do not follow the maintenence schedule it will void any warranty, whether be factory or extended. Also once fluid is brown and burnt damage has already been done to the transmission.
Old 01-05-2005, 02:08 PM
ghostguy6's Avatar
ghostguy6 ghostguy6 is offline
Send a message via AIM to ghostguy6 Send a message via MSN to ghostguy6 Send a message via Yahoo to ghostguy6
Ive heard of that happening before, there are 2 filter kits that are almost identical, the same filter and the same tranny pan gasket, the only difference is the "O" ring that holds the filter in place. One ring is black and the other is red, the red ring is slightly smaller and causes the filter to come loose after a period of time. The service manuals at many shops have the filter numbers reversed so it is possible you have (or had) the wrong "O" ring in your tranny and it cause the filter to come loose. Its an easy fix if thats all it is.
Want to be a mod? Join up at www.mypicgallery.com and PM me.
Old 01-05-2005, 03:14 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Lol, my brothers 92 lincoln continental, 120K miles, gets a tranny flush, TRANNY EXPLODES ON THE HIGHWAY...
Fluid everywhere, all the gears in the tranny where eaten up.
From what i've been told, and know, from experiance is that if the car was maintained (tranny fluid flush every 25K miles) with the PROPER fluid. Make sure they dont use GM fluid on a Ford :-) Everything should be fine.
Now, just doing a pan drop, and drain is the most retarded thing i've ever heard. Thats like only replacing your oil filter, not the oil. They have to completely flush the trans, and the torque converter, EVERYTHING. Then replace the fluid.
BTW, i've seen this trend with mostly american cars, not to many japanese cars....hmmmm..
Old 01-05-2005, 04:10 PM
Yes, tranny repair shop touched on the same thing today when they called me. They are going to replace filter and see what happens.
Old 01-12-2005, 08:34 PM
deadBird's Avatar
deadBird deadBird is offline
http://www.trustmymechanic.com/transslip.html
This little article explains why newer cars would be perfectly fine to do a transmission flush. It's the older vehicles you don't wanna do it with.
Old 01-24-2005, 08:38 AM
Yes, thank you. Very interesting.
