Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-02-2005, 03:25 PM
Syn48 Syn48 is offline
piecing together a turbo kit
Hi all i plan on turboing my 01 RS this summer and i have a few questions. first off i am trying to put together a list or parts i am going to need and so far all i have picked out is the turbo its self so i need help in choosing other parts.
here's the list
T3/T04E turbocharger Turbonetics 50 Trim T04E Compressor
fuel management? i have read most people like the greddy E manage? but are there other or better options
also am i going to need to do a new exhaust system or will the stock 2.5" ( i believe) do fine?
new injectors? what size would be recomended
please fill in anything else that i may have missed i am trying to keep this on the low budget end so if you could point me in the direction of a good place to get used parts it would be great.
thanks for your time
Old 01-02-2005, 03:33 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: piecing together a turbo kit
you can go with the 440 1g/2g injectors. ive heard that the emanage is about the best. thats what i would go with. go with a 3'' exhaust. some people go custom with the exhaust with a high flow cat. i dont know if that turbo has an internal wastegauge. if not, then you would need one of those. most people use tial
Old 01-02-2005, 03:38 PM
thanks wont i also need an intercooler and where could i find some decent used parts also the injectors you mentioned the 1g/2g means from a first or second gen eclipse? oh and will i need to put in new headers? or should stock be able to handle the power increase.
Old 01-02-2005, 07:24 PM
Stickin_It_2_Em's Avatar
Stickin_It_2_Em Stickin_It_2_Em is offline
Banned
Thi is just the asshole in me coming out... but when you said "oh and will i need to put in new headers? or should stock be able to handle the power increase." Well this is exactly when I knew you have no idea what you are talking about. Not that their is nothing wrong with this, but by your first post Ithought you might have some knowledge of turbo's. First off... there are no header's on turbo's...they use an exhaust manifold. Contraire to popular belief header's, and manifold are two different things. Please go to this website and look around. It will tell you EVERYTHING you need to know about turbo's, and everything else you never wanted to know about anything! http://auto.howstuffworks.com/turbo.htm
Old 01-02-2005, 07:41 PM
i have been to that site previously and read about turbos on fiautosports.com and your right i dont know too much about it but by the time i am ready to order the parts i should have sufficient knowledge.
the only reason i asked about the headers was because i thought with the power increase i need to strength engine parts and i thought that perhaps with the amount of power being added that it might crack the headers.
Old 01-02-2005, 10:47 PM
Re: Re: piecing together a turbo kit
i guess this is the asshole in me....but tell me the difference between headers and exhaust manifolds. how about you do your homework. take a look at the site you gave. go to the search bar at the top and type in "exhaust manifold". in the results, you will see a link for "How Do Exhaust Headers Work To Improve Engine Performance?" from HowStuffWorks. please read that article before you decide to be an asshole again. thank you and ill be here all night
back on topic, yes you will need an intercooler if you plan on running more than 5psi. and for the "headers/exhaust manifold", the turbo manifold/turbo headers from the 2G GST/GSX will bolt right up to your RS. just to let you know, the piping from the intercooler to the throttle body is the crucial part of the kit. if you can get quality pipes, the rest will take care of itself
Old 01-02-2005, 11:52 PM
Banned
If I'm wrong I appologize. I found this litte atricle on the web which best explain's why I believe there is a difference between header's, and exhaust manifolds... but I have been wrong before.
"Exhaust gases leaving the combustion chamber are forced out by the piston on its up-stroke. Any resistance from the exhaust manifold results in power loss. Typically a stock manifold has a common chamber where the gasses must meet before they move down into the H-pipe. If the exiting gasses run into each other they create back pressure. Headers are individual pipes which allow the gasses to flow more easily into the area where they are collected. Equal length headers insure that the pulse associated with the escaping gasses is timed correctly so that each meets at the collector separately. Headers are an excellent method of freeing up valuable power. Typically they can produce 15-20 hp. Long-tube headers are also good for some additional low-end torque"
http://66.102.7.104/search?q=cache:8...manifold&hl=en
Old 01-03-2005, 07:08 AM
http://auto.howstuffworks.com/question172.htm
in this article, it refers to headers and exhaust manifolds as one and the same. thats b/c they are the same. just two different names.
Old 01-03-2005, 08:34 AM
dickswhip00gs dickswhip00gs is offline
you can use the header from the gst/gsx, but you will not be able to run the t3/t4. its too big and will hit your a/c. you'll have to use a 16G turbo, which is just as good, if not better than the t3/t4. its smaller, allowing it to spool up a bit quicker, and its durability has been long proven. you will also need to get the oil feed fitting welded to oil pan. any good welding shop can easily do this. also youll have to get the e-manage tuned. find a good car shop with a dyno to do this. hardest part, if you buy a kit, is taking off the front bumper, but from there on out, its (with a kit) a bolt on job. you didnt say if its auto, manual. also you need bigger tires. 225's should work. there are so many more things you can do, but you better have a big budget.
Old 01-03-2005, 09:37 AM
i did not know about the t3/t4 not being about to fit with the gst/gsx headers. dont forget about a bov. i dont know how you can forget about that. also, i thought he was just asking about parts for the turbo kit so tires would not be included. there are tons of other parts he would need for his car that arent exclusively for the turbo kit
Old 01-03-2005, 11:33 AM
very true, tires were just something i was thinking of at the time. you could sit for hours thinking of all the little things. either way, a kit is the best way to go. good luck syn!
Old 01-03-2005, 01:39 PM
thanks for all of your help i will definitely post in the comming months on the progress.
it is manual transmition also you mentioned tires is that just so i will have better traction for increased power?
Old 01-03-2005, 02:18 PM
yes b/c traction will probably be the biggest problem...also dont forget about the electronics side of it, like an electronic boost controller. and dont forget about gauges
Old 01-04-2005, 02:10 PM
when i do the installation do i permantly lose my front bumper due to the intercooler? if so then if i get into a minor crash would it cause a huge difference in damage to the front end the it wold if i still had the bumper in?
you'lll have to excuse me on this issue i dont fully understand the intercooler mounting.
Old 01-04-2005, 02:31 PM
no no no...you will keep your front bumper. but depending on the piping, you might lose one of you bumper support brackets. if you go over to www.club3g.com, pm eclipsePenguins, napalm, or xull1x. they have installed intercoolers on their RS/GS. they would probably be able to help you out the most since they have been through it. dont tell me you really thought that you were going to drive around with no front bumper??
