Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-02-2005, 03:20 PM
SOLSTER SOLSTER is offline
Sylvania Silverstar Headlights
Can anyone recommend the Sylvania Silverstar Headlights for the '99 rodeo?
Or, does anybody know of problems with these?
I have long felt my headlights are too dim, and would like an improvement.
Thanks,
SOSLTER
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 01-03-2005, 08:40 AM
TampaMike TampaMike is offline
I have the Silverstars in my '02 Rodeo LSE and previously in my '98 LS. I find them a big improvement over the stock bulbs. I had tried the 'blue' hue bulbs from some of the aftermarket / performance vendors (including Crutchfield) and they either blew out within weeks, or blew the fuse (even with the correct ratings for the vehicle). So, as a last try, I put in the more expensive Silverstars and have been happy with them. They are a bright white glow, not blue or purple, but sharper & brighter than the yellowish stock bulbs). They have been in my '02 LSE over 2 years now without any problems. I also replaced my fog lamp bulbs with Sylvanias.
Old 01-04-2005, 03:13 PM
TheFugitiveMind TheFugitiveMind is offline
Re: Sylvania Silverstar Headlights
been using then for about 6 months on my 01 passport. they work wonders! worth the cash!
Old 01-09-2005, 12:25 PM
Tom01Rodeo Tom01Rodeo is offline
I still have the stock bulbs but it seems one in five cars will flash their brights at me even though I'm on low beams. Any one else have this problem? Its very annoying.
I may need to adjust the headlights. Anyone done this before?
Ryan- how about a procedure for your faq?
Old 01-09-2005, 12:34 PM
EASY, grab a philips head, there are three adjustment screws that you access from the front looking right into the headlight, at least that's how it works on my '99. Mine came pointing to low, I adusted up, but still need something better.
Finally, something a pc geek can answer! But don't expect any transmission replacement answers fom me ;-)
thanks for the recomendations on the sylverstars!
Old 01-10-2005, 03:27 PM
megavolt121 megavolt121 is offline
Re: Re: Sylvania Silverstar Headlights
which screws? take a pic, ur a self proclaimed pc geek right?
Old 01-10-2005, 04:18 PM
amigo-2k amigo-2k is offline
Isuzu Guy
http://www.ehow.com/how_112704_adjust-headlights.html
I don't know if this will help, it is pretty generic.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-10-2005, 09:51 PM
Re: Re: Re: Sylvania Silverstar Headlights
seriously? You mean simply looking directly at the headlight for the screws is too difficult??
Okay, for those that are less mechanically inclined than me (which is hard to believe anyone is), I'll take a pic....... Do you need a pic of what a "philips head" is also
just jokin' round megavolt
Old 01-10-2005, 10:27 PM
Here's the pic.
I said 3 screws from memory, actually 2, one for horizontal and one for vertical control. they are on a spring, so lossening or tightening them is how they adjust the lamp.
image looks cr*ppy due to the 80K image file size restriction!
SOLSTER
Old 01-10-2005, 10:35 PM
ah.. i thought those screws were used for holding the lamps in place. that's why i didnt want to mess with them.
Old 01-10-2005, 10:40 PM
Isuzu Guy
so how do we change the bulb?
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-10-2005, 11:01 PM
Look under the hood, press the tabs to pull out the connectors. Then you'll see a Plastic ring that holds the bulb in place. All you do is unscrew it and the bulb comes right out. I didnt have a problem with taht
Old 01-11-2005, 01:48 AM
The adjustment method above is from memory, and it was 5 years ago I did it, so, use some best judgement, I don't recall if the screws have stop points, or will screw all the way out. Don't let your headlights fall out on account of me....... But it did work!
I did the bulb replacement once, don't remember the steps, but it was easy and intuitive, again, this comes from a "what's a clutch" pc geek.
megavolt's insructions sound very familaiar to what I remember!
I can look into it if you ask again!
SOLSTER
Old 09-03-2006, 10:33 PM
LuxAeternaDT LuxAeternaDT is offline
I know I'm bringing up an old thread but I just want to tell everyone about my experience with Silverstars. I had my right headlight go a few days ago, and the rodeo with one headlight is really dark. I've never really thought the stock headlights were good so I figured since one went out I could swap the stock bulbs for something better. I picked up a pair of Sylvania Silverstar 9004ST headlights and wow what a difference. These headlights are definately worth the $40 for the pair and a big improvement over stock. Now they are more of a solid white then a yellowish white. I believe the stock headlights were Sylvania 9004's. Just wanted to give everyone the review, hope this helps.
1999 Isuzu Rodeo LS 4WD in Spruce Green Mica. Mods: 35% tint, Mobil 1 Synthetic Oil, K&N Drop In Filter, Pioneer DEH-P6700MP CD Deck, Sylvania 9004SU Silverstar Ultra Bulbs.
Old 09-04-2006, 12:48 AM
jimwelsh's Avatar
jimwelsh jimwelsh is offline
Get Silverstars. I had them in my 87 Trooper, and when my Trooper quit, I put them in my 99 Rodeo. Makes quite a difference.
Jim
