Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 01-02-2005, 02:29 PM
seriousfour seriousfour is offline
Angry 1999 Expedition sometimes doesn't start
I have replaced the starter, replaced the battery, but there are still times where the car doesn't start.
I have tried changing keys thinking it might be the chip on the key.
I am at a loss, there is no consistency at all. The other day my wife and kids got stuck, called AAA and they tried everything, nothing worked...They tried boosting it, shorting the starter, but nothing...
She then waited 45 minutes, turned the key an the car started...
HELP!!!!
Any ideas would be greatly appreciated.
Thanks and Happy New Year!
Old 01-03-2005, 06:14 PM
spadoni spadoni is offline
Won't start
ok you have replaced everything that is obvious but now to the simple stuff that sometimes goes over looked. 2 thinks come to mind.
1. you need to have the sensor under the brake peddle checked to see if it is working correctly. As you probably know you have to have the brake depressed due to a sensor. Check that one.
2. there is also another saftey device on the coulum to make sure it is in park. Check it also. either way this will cause the vehicle to not even turn over.
Old 01-08-2005, 12:16 AM
al52269 al52269 is offline
Re: 1999 Expedition sometimes doesn't start
HELP!!!!
Hello!
Hope your well...
Check the Neutral Start Switch is located on the Transmission.
Hope this helps, Sincerely, Al
Old 01-13-2005, 02:48 PM
FordExp2000 FordExp2000 is offline
I am having EXACTLY the same problem with our 2000 Expedition. After a short drive (like to the grocery store), I come back out and the car will not start (lights work, but no clicking of the starter). After about 45 minutes, it starts.
It always starts in the morning, and after it's been sitting for 45 minutes, but it occasionally refuses to start when it has been off for less than an hour. (Like when running errands or stopping to fill-up with gas).
The Ford Dealer has not been able to duplicate the problem = no help.
At first, we thought this only happened on hot days (over 80), but this has been happening more often now.
I've replaced the battery - no difference.
Someone suggested the solenoid, but there are 2 and the dealer says the one on the firewall never needs replacing ($90+) and the one on the starter will require a complete replacement of the starter ($500+).
Please let me know if you've found anything that works --
Many thanks,
Old 01-14-2005, 10:50 AM
jdsmith75202 jdsmith75202 is offline
Send a message via Yahoo to jdsmith75202
Please see my reply at http://www.automotivehelper.com/topic344975.htm
HELP!!!!
Old 01-14-2005, 11:42 AM
Re: Re: 1999 Expedition sometimes doesn't start
Originally Posted by jdsmith75202
I read your posting about gas filter and ether, but it is not that it is difficult to start, it does not have ANY movement by the starter. When I turn the key, I get dashboard lights, but no starter. Something is preventing the starter from doing anything. I ruled out the fuel system, because I didn't think it would be preventing the starter from being activated.
When you had your problem with starting, did you hear the starter?
Thanks!
Old 02-25-2005, 03:41 PM
FLEXTHEDOG FLEXTHEDOG is offline
Angry Expedition 2000
I am experiencing the same fault with my 2000 Expedition. After short journeys will park up the car, return and will not start the dashboard lights are all working but the engine doesn't even crank over. Leave it for about 45mins+, it starts.
It is now going to the Ford Dealer for the 3rd time on 28th Feb.
1st occasion the cut me new keys, worked great for about 5days then problem returned.
2nd visit they replace a new ground cable, worked fine for 22days and problem returned.
The Ford guys don't seem to have a clue what is going on. As anyone solved their problem YET!!!!!!!!
Help would be greatly appreciated, on the verge of trading the car in.
Thanks
Old 02-27-2005, 10:03 AM
I'm sorry to hear that you are having the same problem.
We're still trying things, but without guaranteed success.
Our latest effort is to make sure the car is firmly in PARK before turning the key off - thinking that it may be due to contacts in the steering column not being in alignment.
I doubt this will prevent the problem.
I'm predicting it is a problem within the steering column ( = expensive). Our Ford dealer has not been able to duplicate the problem in their shop, and brush us off when we ask if this has ever happened to another Ford customer.
Is there a contact at Ford who will investigate something like this?
I'll let you know if we find a solution to this.
Old 02-28-2005, 01:56 PM
Thumbs up re:1999 expedition won't start
Just got off the phone to the Ford Technician, he seems to think he has the problem solved.
The Transceiver Pins in the steering column were loose, now he his very confident this is the problem. Only time will tell !!!!!!!
Can only suggest you all check yours. Will drive it for a week and let you know the outcome.
I have no contact name at Fords. Have been in touch with Ford Canada only to be told they have no troubleshooting dept, this I find very hard to believe.
Will see how I get on now with these Pins tightened. If no good,then will
keep pestering Fords until the matter is resolved.
Fingers Crossed............
Old 03-09-2005, 04:41 PM
mythreesons mythreesons is offline
Re: re:1999 expedition won't start
Well, this seems to be going around. My Expedition is at the dealership after stranding me for the second time in 2 weeks. Same as other post, a short trip and run in to get my sons from school, get back in and the car won't start. GRRRRR
The dealership can't figure out what is wrong because of course it started right up once it got towed to the dealership. I will say that both times my car was parked on a slight decline and I had a little over 1/4 tank on both occasions (At least 60 miles till empty)
I just can't have an unreliable car with all of the carpooling I need to do. I hope this can get resolved.
Old 03-11-2005, 02:59 PM
Angry
Well guess what, it weren't any transceiver pins. Again went back to the dealer only this time they contacted Ford Canada.
Apparently this is not an uncommon fault, my local dealership were told it is a badly fitted windscreen which lets in water and makes it's way to the fuse box, thus causing the no start.
This I found hard to swallow, but would by now give it a go (anyway I weren't paying for it). I was present when an Windshield company removed my windscreen, belive it or not there was at least 8inches of windscreen which had come unstuck from the frame.
Car worked great for a few days and guess what. YEP it happened again, now I have been told that the fuse box should have been replaced aswell as it was damaged from all the water getting in.
This I can safely say will be the last effort I will allow them to try, a rather nasty letter as been sent to Ford demanding full refund on all unecessary worked carried out.
Will try this for a short time, if it does not work have decided to trade in..,
Old 04-20-2005, 05:46 PM
jacky66 jacky66 is offline
2000 expedition sometimes won't start
I'm also having the same problem with mine. since the Cruise Control was disconnected for the recall problem. It has happened 3times this month alone. AAA won't tow no more have been stranded for 4 hours wainting for tow truck got to dealer started right up.Of course they can't do anything about because is started. Had to have the starter jumped yesterday got home wouldn't start when I tried it tried 2hrs later nothing. Waited morning started right up ?!?! I Give up. It going to the shop again on Wednesday if it'll start so they can keep it & see if it does it to them. If you jump the starter it will run. My brother is a GM mechanic & says if you can jump the starter it is definetly not the starter. He says it could be ingintion switch, neutral safety switch. Has anyone got the problem solved yet. I even call Ford corp. complaining about this problem and just told me. that the problem is on file. Please Help
Old 07-20-2005, 09:55 AM
BBrDawg BBrDawg is offline
Add me to this mix....I have that won't start too! HELP!
Old 08-19-2005, 02:38 PM
Irish 12 Irish 12 is offline
same prob but fixed
it a relay switch in the little black cilinder that is atached to the bat. cabels up top it cost 4 to 6 bucks and easy to replace
Old 08-19-2005, 11:46 PM
starter cilinoid
i looked at the box and the part was a starter cilinoid 4 to6 bucks easy to replace
