Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-02-2005, 12:50 PM
bugsas99 bugsas99 is offline
top of motor
the previous owner of my aurora painted the top plastic piece white. why i don't know what can i use to remove the paint without diong too much damage
Old 01-03-2005, 06:44 PM
dmorlow dmorlow is offline
Re: top of motor
Laquer Thinner probably.
Old 01-03-2005, 08:08 PM
GuMan GuMan is offline
Rather than strip it, if it is not too thick, look
into some metallic engine paint. You can get
this in the original look metallic silver and respray
it. I sprayed mine because the original paint
they used had started to wear off. You realize
that laquer thinner will probably start to degrade
the material, and will definately strip the original
paint off too. It is black underneath.
Old 01-31-2005, 06:08 PM
Re: top of motor
Well, if you want it to stick, you might be better of stripping it to the black. Then paint it metallic. Painting over a couple of layers of other paint isn't going to look too good.
