Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-02-2005, 12:12 PM
seas seas is offline
Question heater switch melting
I have a 99 Wrangler 4.0 with AC. The problem is that heater control switch and the vent control switch both melt down. Every year(around Decemeber)I would lose high speed first. That is when it starts to melt. Soon after, all speeds are lost. When the switch cluster is removed, you would notice how everything is melted. Four trips so far to four different dealerships and none can determine what the exact problem is. Every trip seems to involve a replacement of the switch cluster and blower motor which does correct the problem, but only for a year. There must be something else going on that I am melting this stuff......Please help!!!
Old 01-03-2005, 03:24 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: heater switch melting
Wow; sounds nasty. I'm not an electrical guy, but it sounds like there is a bit too much voltage flowing into the system. Do you have the correct amperage on your alternator? How about voltage regulator; have the dealers checked that?
Sounds like they're treating the symptom rather than finding the underlying cause of the problem. You might want to try a reputable auto electronics shop, they may be able to trace the voltage condition.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-03-2005, 04:37 PM
JDPascal JDPascal is offline
Ask the shop to give you the old blower motor. you can then check the blower motor for tight bushings or for shorted windings. It is high amperage that will melt the switch.
Do you live where they use a lot of salt on the roads?? that might work its way into the motor bushings or other places and cause problems.
You could probably figure out how to connect a digital ampmeter in the circuit and find out what the real draw is on the old one and compare it to the new.
One other thing to check is the heater motor resistors. There might be something there that is causing a repeat of the problem.
JD
