Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-02-2005, 01:00 PM
ssamaan1 ssamaan1 is offline
1997 Maxima SE- slow to start
For the last month when I start my car it takes some time....like a couple of seconds. I know it is not the starter. So, this morning it took at least a minute to start.
I got the normal, slow (I will try and spell and sound it out) Chug....chug...chug...and then it go faster as I light tapped at the gas....chug..chug..chug...
then it finally started after a minute.
Do you think I need to replace the fuel injector?
Thanks!
Steve
PS..the car is like new, great shape, 107000 miles. Nothing added, just a good old fashon Nissan Maxima.
Old 01-02-2005, 01:58 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 1997 Maxima SE- slow to start
- All connectors oxidize by age, not by miles:
http://www.cardomain.com/memberpage/748507/14
- Thin Rubber tubes get brittled at that age. Inspect, replace or cut bad ends off.
- Idle assy has to be periodically cleaned, that time is loong overdue.
- Coils wear, get cracked. Replace or try to add insulation.
- if pedal movement is the key issue, Throttle Pos Sensor should be replaced.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-10-2005, 05:48 PM
Mr. Apollo Mr. Apollo is offline
Something similiar happened to my 1997 SE. It was the fuel pressure regulator.
Old 01-18-2005, 02:52 AM
ILOVEMY69 ILOVEMY69 is offline
Send a message via AIM to ILOVEMY69
I would say have a tune-up done. I had a similar problem and it was the ignition switch which was not too expensive so maybe you should have it checked out.
-Eddie
1969 chevy nova sb 350
1995 Nissan Maxima totalled 8/11/04
Old 01-18-2005, 02:56 AM
BodyKits's Avatar
BodyKits BodyKits is offline
Banned
check the regulator. if you need one i know where you can get a real nice one cheap.
