Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-02-2005, 01:07 AM
98AUR0RA 98AUR0RA is offline
Send a message via AIM to 98AUR0RA
Check Engine
Is there a way to see why my light went on with out it costing alot of money to check it. i was driving home when i noticed my light started to blink then it stopped blinking and stayed on. then started blinking again. does anybody have a clue?
Old 01-02-2005, 12:27 PM
dmorlow dmorlow is offline
Re: Check Engine
A 98 Aurora has a true OBDII system. You should be able to buy a cheap $30-50 scantool. My car is a 95. It was a transition year between a OBDI and II so I had to buy a $500 scanner to read it. But anything 96 and later can use the cheap OBDII tool. And I believe that Autozone will scan your car for free.
Old 01-02-2005, 01:18 PM
Isnibs's Avatar
Isnibs Isnibs is offline
98AUR0RA
Try
'http://www.automotiveforums.com/vbulletin/showthread.php?t=204365'
Remove leading and following '
read the post by dsatt12
1996 Aurora Black / grey
Old 01-21-2006, 08:54 PM
apollo7879 apollo7879 is offline
Re: Check Engine
Go to any Autozone store. They will use there scan tool & tell you what system in your car caused your light to come on, at no charge.
If you plan on doing your own work, it's a good idea to purchase your own diagonstic tool.
Old 01-21-2006, 09:01 PM
Re: Check Engine
Sorry, dmorlow, I now see you had allready posted the same info that I did.
